Any word on solution?
try to follow these instructions? http://www.macosxblog.com/how-to-fix-coretelephony-trace-file-error-on-mac/
also, double check you arenāt out of disk space
Iām like 95% sure the permissions on your /tmp directory are bad (the url above helps you fix that) ā it explains the lock file error in Roon too.
Thanks Danny
I tried 1-3 and still get th error message
Not sure how to create directory for solution 4???
I also think I did not do 2 correctly. Where is /private? I searched in settings and did not find it.
John, Thanks for trying those. I tried #1 without success. I wasnāt sure what private was either.
In Finder, click Go, then Go To Folder. You will need to type /private
with the slash.
Once you have the Private folder open, you can follow the instructions or press Apple + I to open the Info popup.
I am using screen saving and thus my desktop is a bit different
anyway, I am in sharing and permissions and it says read only, not sure how to change???
Thanks so much for the help
Youāll need to click the little lock to make changes, then you can click the various permissions (Read|Write) to change them.
Unlocked, clicked on read and write, nothing, locked again, nothing, unlock, repeat, etc. Nothing.
Still on lineā¦
was able to change to read and write (had to change all 3 user types), still not workingā¦
Thanks John, For what itās worth my MacMini is a 2012 I7 upgraded with ssd by OWC purchased at the end of June. I was unable to change permissions in /private folder, even after I unlocked it, it said I didnāt have permission to change read/write options. l only had read privileges.
So, using the Mac OS blog instructions just about cratered my OS. MAC support says not to use them.
They are trying to find a fix now. i will post results.
Eric or anyone from Roon. Apple is no help. They sent the issue to an engineer who will get back to me in a week.
In the meantime, I would sure love to have some music given how much I spent on the sw.
If I download a new Roon, I assume that will lose all the changes I have made (integrating tidal albums into my library, etc)?
Any more ideas? Seems awfully weird that a reboot would have this effect.
Thanks.
BTW, Apple claims this is an issue with the iPhone sync to the iMac (something i didnāt think I had set yp). Not clear why that would prevent Roon from opening.
John, I deleted Roon and downloaded a new copy opened it and got the same error. I did not delete my Room library file.
