Running an HP PC running Windows 10 as Core. Roon Version 1.6 (build 416).
Running Roon Bridge Version 1 (build 168) Allo USBridge attached to core with Cat 6.
Router is SAGEMCOM FAST 2864
Wireless Access Point is an Arris VAP2500
HP (Core) attached by Cat6 to USBridge attached to a Nuprime DAC-9
When I first set up the CCA 2 days ago roon was able to see it and I played music to a portable speaker. Next day roon could not discover it. No luck at all since then.
I have:
reset CCA to factory settings and re set-up.
turned off and rebooted everything
tried Guest mode both off and on
Note that the CCA will stream from Google music and appears to do everything it is supposed to do.
I was able to ping the CCA from the Desktop successfully
The Core is connected by wifi.
The CCA is wifi.
No other network gear.
The PC where the core is located has
IP 192.168.2.10
The CCA has IP 192.168.2.35
