Just got a Project S2 streambox. Roon does not see it as a choice to be enabled. Any ideas on this? the S2 works, will send a USB signal to my DAC and play music from other sources, but not Roon.
I think I recall some setting in the S2 might be needed to enable roon
Is it the Streambox Ultra? This is Roon certified but I’m not sure the standard S2 is.
Yes it’s the S2 ultra
I finally found the setting to turn on Roon in the settings. Good to go now
