Running HQ Player with Roon. Converting all files to DSD 128. Most of my files are FLAC some DSD64 and Tidal.
When using say songs from Queue or radio when songs change from say a FLAC file to DSD lot of times I will get a loud pop sound between track. Say I play all songs from same file format it doesn’t happen. Also still sometimes music stops in between tracks.
I did giggle at the original typo in the title imagining Jussi reading it; (pooping sound ?)
But, more constructively, what DAC are you using and do you have another DAC that you could swap in and compare to see if this is DAC related or file/player related ?
Went into cross fade setting and set cross fade at 3 secs. Seems to have stopped the popping.But now when I play a 64 dsd file in source it shows dsd64 to pcm 352.4 with a green circle beside it.It then up samples to dsd 128 which is what my settings are in Hqplayer.Why does it convert the dsd file to pcm when I add cross fade ???
Also it converts from 16 bit to 24 bit while playing Tidal tracks with the green circle before passing to Hqplayer.Adding cross fade shouldn’t change anything should it ?
Adding crossfade = activating Roon’s DSP engine. So does turning on volume normalization.
This has a few side effects: it forces DSD->PCM conversion (because we don’t have a DSD processing engine as of now), and also losslessly expands 16bit content to 24bit to make more headroom for the ensuing DSP.
Some DACs don’t engage output mute when switching sampling rate or settings. With DSD this tends to cause pops at that point. So this is more likely to happen when “Auto rate family” is enabled.
Please observe if there is source format change when this happens and whether you have “Auto rate family” enabled…
