I have been using Roon on my MacBook Pro with OS Sierra for a few years…
All of a sudden will not open up so I can play music. When I launch instead of opening it goes to a window
“Choose your Roon core”
which I’ve never had to do. My only real option is to select “setup a Roon Core on this Mac”. Then I am asked to login and so I do.
It then says I’m already signed in to this macbookPro. if I want to connect to it just hit the go back button. And I’m back at the “choose your Roon core” screen.
So basically I’m in a loop where I can’t ultimately connect to me Roon and play music
