Roon core (QNAP NAS dedicated to Roon) is hardwired Ethernet to the same UniFi switch as the PC where music files are located.
Roon Remote running on iPad and iPhone
BlueSound Node2i and Devialet Phantom Reactor speakers.
After a Power Outage my QNAP NAS restarted and everything came back and it took awhile for Roon to restart. Once the Roon Core was up, my roon remote (iPad/iPhone) displayed a message Waiting for a connection which never went through.
Upon clicking “select a different core” it found the NAS but it wasn’t able to display music. It said the library could not be found. After much trying, I decided to remove and re-add the music file share. This initially took a while but always errored out with a similar message saying it could not access the share.
I restarted the NAS, my PC, the iPad no difference
After much trying I removed and reinstalled both Roon Remote and Roon Core and I now get an error when trying to add the share it errors right away with a different message saying: “Could not connect to share: Unauthorized”.
I verified the share is up and accessible from all other devices including Sonos, Node 2i, my other laptop and from the iPad running SMB explorer app.
Is Roon caching the NAS connection string somewhere and causing this weird behavior?
Any ideas on how to reset the Roon remote so that it sees the share?
What’s interesting is that the error is instantaneous, like it’s not even trying to connect like it was previously. Before re-installing everything the roon remote would take about a minute or longer to timeout after trying to connect and the error was different.
I’m creating a test share to try again and see if that helps
Same problem with a new share I just created from scratch. I also removed and re-added the same share from the BluOS controller and reindexed without issues, so I doubt it’s a share issue.
Adding a share in the NAS seems to work but that’s not where my music is right now. Both NAS (Roon Core) and PC are hard wired to the same UniFI switch.
Looking at the logs here’s where it seems to be failing:
It’s past midnight here in California, I’ll go to bed and try again tomorrow.
I keep thinking there’s something left behind (a config file or setting) in the roon core possibly a corrupted state which is not letting it try the connection.
I can’t find the thread, but I recall that one user had to place his complete Microsoft login instead of just the username, e.g. Luis@Microsoft.com instead of just Luis for the username.
Deinstalled and re-installed roon core through Appcenter.
I did reboot the networking gear as well both wired and wireless just in case.
SMB1.0/CIFS Server is enabled on the laptop. Again Sharing works with all other devices in the same network
I have tried both luis and luis@xyz.com and multiple combinations of uppercase and lowercase. Prior to the power outage this was working fine with the same credentials and sharename
The roon remote is only sending commands to the core to connect to the Library, right? and not really part of the equation so it’s just the roon core the one that’s having the connectivity issues. I just deinstalled the core and noticed it leaves behind a bunch of folders in the volume. I’m going to re-format that 128G SSD volume and try again.
BTW is this the right way of installing the Core and DB?
Finally got this fixed. I reformatted the drive where Roon Core was originally installed so all the old folders were gone and then re-installed the core as usual. It still didn’t seem to like the luis@xyz.com account I was using (nor the previous “luis1” account I was using) so I also created a new “luisx” account and password and that plus the above took care of the problem. So it does seem to be some weird credential caching going on.
For the record, just for kicks I removed the library and re-added it afterwards with “all lower case” and no problems at all so it is NOT CASE SENSITIVE.
Anyway, thanks everybody that chimed in to help!! I’ve earned my drinks today and that’s where I’m heading now
Maybe not case sensitive on your qnap but on synology and just about every other nas or server I’ve setup they are … anyway you are up and running so happy days.
