installed Roon two weeks ago, Did the import procedure and started running. It worked great for about half an hour and then crached, It didnt ReStart,
Eversince the program just won’t launch. it did a couple of times but crashed immediately.
Hi , I have a similar issue. Roon was working fine but now won’t launch. Nothing on the PC has changed. I’m running 64 bit Windows 10. Any ideas ? Thanks … Tony
