Windows 11
Eero Wifi, roon endpoint wired to eero
Allo USBridge Sig with up-to-date RoPieee
55,000 tracks
My Roon endpoint running RoPieee is not appearing as a zone to be enabled, though it appears in Roon’s About section as a fully up to date Roon Bridge. I have tried deleting RaatServer data and reinstalling RoonServer on core PC
RaatServer Log
04/14 15:24:49 Info: Starting RAATServer v2.0 (build 1244) production on windows
04/14 15:24:49 Info: Local time is 4/14/2023 3:24:49 PM, UTC time is 4/14/2023 7:24:49 PM
04/14 15:24:49 Trace: [bits] myinfo: {"os":"Windows 11","platform":"windows","machineversion":200001244,"branch":"production","appmodifier":"","appname":"RAATServer"}
04/14 15:24:50 Warn: [easyhttp] [1] Post https://bits.roonlabs.net/1/q/roon.base.,roon.internet_discovery.,roon.raatserver. web exception without response: The request was aborted: Could not create SSL/TLS secure channel.
04/14 15:24:50 Warn: [bits] http request failed updating bits, status code: 999, message: <<NULL>>
04/14 15:24:50 Info: [RAATServer] creating RAAT__manager
04/14 15:24:50 Info: [RAATServer] appdata_dir = C:\Users\jeffr\AppData\Local\RAATServer
04/14 15:24:50 Info: [RAATServer] unique_id = c0be1e77-d5f8-48ba-a754-692ce5aa1fcc
04/14 15:24:50 Info: [RAATServer] machine_id = ed930802-62c8-ed40-2b0b-65ad9769b214
04/14 15:24:50 Info: [RAATServer] machine_name = JEFF-OFFICE
04/14 15:24:50 Info: [RAATServer] os_version = Windows 11
04/14 15:24:50 Info: [RAATServer] vendor =
04/14 15:24:50 Info: [RAATServer] model =
04/14 15:24:50 Info: [RAATServer] service_id = d7634b85-8190-470f-aa51-6cb5538dc1b9
04/14 15:24:50 Info: [RAATServer] is_dev = False
04/14 15:24:50 Trace: [raatmanager] starting
04/14 15:24:50 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{0a33f417-3ada-495c-9897-1917c9c801e1} usb_id=
04/14 15:24:50 Trace: [raatmanager/windows] name=NVIDIA High Definition Audio output_name=PA278QV
04/14 15:24:50 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{28ab4b40-6ba8-412a-aead-ae9528dfa5d0} usb_id=08bb:2704
04/14 15:24:50 Trace: [raatmanager/windows] name=USB Audio DAC output_name=Speakers
04/14 15:24:50 Trace: [raatmanager/windows] FOUND type=wasapi id={0.0.0.00000000}.{4e7014ff-a240-48ff-aad1-6716145a9ead} usb_id=
04/14 15:24:50 Trace: [raatmanager/windows] name=NVIDIA High Definition Audio output_name=S2719DGF
04/14 15:24:50 Trace: [raatmanager] initialized
04/14 15:24:50 Warn: [raatmanager] update_bits, json string: {}
04/14 15:24:50 Info: [RAATServer] running RAAT__manager
04/14 15:24:50 Trace: [raatmanager] starting discovery
04/14 15:24:50 Trace: [discovery] starting
04/14 15:24:50 Info: [discovery] [iface:Ethernet:192.168.7.137] multicast recv socket is bound to 0.0.0.0:9003
04/14 15:24:50 Info: [discovery] [iface:Ethernet:192.168.7.137] multicast send socket is bound to 0.0.0.0:56179
04/14 15:24:50 Info: [discovery] [iface:Loopback Pseudo-Interface 1:127.0.0.1] multicast recv socket is bound to 0.0.0.0:9003
04/14 15:24:50 Info: [discovery] [iface:Loopback Pseudo-Interface 1:127.0.0.1] multicast send socket is bound to 0.0.0.0:56180
04/14 15:24:50 Info: [discovery] unicast socket is bound to 0.0.0.0:9003
04/14 15:24:50 Trace: [raatmanager] starting server
04/14 15:24:50 Info: [jsonserver] listening on port 9200
04/14 15:24:50 Trace: [raatmanager] announcing
04/14 15:24:50 Debug: [discovery] broadcast op is complete
04/14 15:24:50 Trace: [inetdiscovery] added device raatserver/c0be1e77-d5f8-48ba-a754-692ce5aa1fcc in addr:__ADDR__
04/14 15:24:50 Trace: [inetdiscovery] added service com.roonlabs.raatserver.tcp for device raatserver/c0be1e77-d5f8-48ba-a754-692ce5aa1fcc
04/14 15:24:55 Trace: [ipaddresses] enumerating addresses
04/14 15:24:55 Trace: [ipaddresses] FOUND Ethernet 192.168.7.137
04/14 15:24:55 Trace: [ipaddresses] FOUND Loopback Pseudo-Interface 1 127.0.0.1
04/14 15:24:55 Warn: [easyhttp] [2] Post https://discovery.roonlabs.net/1/register web exception without response: The request was aborted: Could not create SSL/TLS secure channel.
04/14 15:24:55 Warn: [inetdiscovery] failed to register: Result[Status=NetworkError]
04/14 15:25:00 Trace: [RAATServer] refreshing @ 10s
04/14 15:25:00 Trace: [raatmanager] announcing
04/14 15:25:00 Debug: [discovery] broadcast op is complete
Roon Server Logs excerpts
Note that the device at 192.168.7.114 was reflashed with a new SD image and is now connecting at 192.168.7.216
04/14 15:26:15 Trace: [raat] RAATServer discovered: RaatServer br-stereo @ 192.168.7.216:9200
04/14 15:26:15 Trace: [inetdiscovery] added service com.roonlabs.roon.api.tcp for device broker/6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3
04/14 15:26:15 Trace: [inetdiscovery] added service com.roonlabs.roon.api.http for device broker/6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3
04/14 15:26:15 Info: [roonapi] listening on port 9150
04/14 15:26:15 Info: [raatserver] GOT SERVER bc6073c1-2059-0d19-a398-b7a1bfe237b1::b1a427fe-eb90-48e8-aebf-e08463c4ca51 @ 192.168.7.216:9200 br-stereo PROTOVER=1 RAATVER=1.1.38
04/14 15:26:15 Trace: [raatserver] [RaatServer br-stereo @ 192.168.7.216:9200] connecting (attempt 1)
04/14 15:26:15 Trace: [raat] RAATServer discovered: RaatServer JEFF-OFFICE @ 127.0.0.1:9200
04/14 15:26:15 Info: [raatserver] GOT SERVER ed930802-62c8-ed40-2b0b-65ad9769b214::c0be1e77-d5f8-48ba-a754-692ce5aa1fcc @ 127.0.0.1:9200 JEFF-OFFICE PROTOVER=1 RAATVER=1.1.39
04/14 15:26:15 Trace: [raatserver] [RaatServer JEFF-OFFICE @ 127.0.0.1:9200] connecting (attempt 1)
04/14 15:26:15 Trace: [raatserver] [RaatServer JEFF-OFFICE @ 127.0.0.1:9200] connected
04/14 15:26:15 Trace: [rnet/RnetJsonClient] SENT {"request":"enumerate_devices","subscription_id":"0"}
04/14 15:26:15 Trace: [raatserver] [RaatServer br-stereo @ 192.168.7.216:9200] connected
04/14 15:26:15 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success", "devices": [{"is_system_output": true, "device_id": "default", "type": "wasapi", "name": "System Output"}, {"device_id": "{0.0.0.00000000}.{0a33f417-3ada-495c-9897-1917c9c801e1}", "type": "wasapi", "name": "NVIDIA High Definition Audio"}, {"usb_id": "08bb:2704", "device_id": "{0.0.0.00000000}.{28ab4b40-6ba8-412a-aead-ae9528dfa5d0}", "type": "wasapi", "name": "USB Audio DAC "}, {"device_id": "{0.0.0.00000000}.{4e7014ff-a240-48ff-aad1-6716145a9ead}", "type": "wasapi", "name": "NVIDIA High Definition Audio"}]}
04/14 15:26:15 Debug: [easyhttp] [26] GET to https://api.tidal.com/v1/sessions/e904888c-afb7-4759-b56d-ca3332708658?countryCode=US returned after 146 ms, status code: 200, request body size: 0 B
04/14 15:26:15 Trace: [tidal/http] GET https://api.tidal.com/v1/sessions/e904888c-afb7-4759-b56d-ca3332708658?countryCode=US => Success
04/14 15:26:15 Debug: [easyhttp] [27] POST to https://api.roonlabs.net/roonmobile/1/cores/announce returned after 146 ms, status code: 200, request body size: 1 KB
04/14 15:26:15 Trace: [devicedb] [autodetect] No Match for DeviceAutodetectData[Type=Local Model=System Output]
04/14 15:26:15 Info: [raatserver] GOT DEVICE c0be1e77-d5f8-48ba-a754-692ce5aa1fcc::default Type=wasapi Name=System Output
04/14 15:26:15 Trace: [devicedb] [autodetect] No Match for DeviceAutodetectData[Type=Local Model=NVIDIA High Definition Audio]
04/14 15:26:15 Info: [raatserver] GOT DEVICE c0be1e77-d5f8-48ba-a754-692ce5aa1fcc::{0.0.0.00000000}.{0a33f417-3ada-495c-9897-1917c9c801e1} Type=wasapi Name=NVIDIA High Definition Audio
04/14 15:26:15 Debug: [easyhttp] [28] POST to https://api.roonlabs.net/discovery/1/query returned after 94 ms, status code: 200, request body size: 74 B
04/14 15:26:15 Trace: [devicedb] [autodetect] No Match for DeviceAutodetectData[Type=Local Model=USB Audio DAC UsbId=08bb:2704]
04/14 15:26:15 Info: [raatserver] GOT DEVICE c0be1e77-d5f8-48ba-a754-692ce5aa1fcc::{0.0.0.00000000}.{28ab4b40-6ba8-412a-aead-ae9528dfa5d0} Type=wasapi Name=USB Audio DAC UsbId=08bb:2704
04/14 15:26:15 Info: [raatserver] GOT DEVICE c0be1e77-d5f8-48ba-a754-692ce5aa1fcc::{0.0.0.00000000}.{4e7014ff-a240-48ff-aad1-6716145a9ead} Type=wasapi Name=NVIDIA High Definition Audio
04/14 15:26:15 Trace: [rnet/RnetJsonClient] GOT NONFINAL {"status": "Success", "devices": []}
04/14 15:26:15 Trace: [SOOD] Adding User IP 192.168.7.216
04/14 15:26:15 Trace: [SOOD] Adding User IP 192.168.7.114
04/14 15:26:15 Trace: [raat] RAATServer discovered: RaatServer RoPieeeJeff @ 192.168.7.114:9200
04/14 15:26:15 Info: [raatserver] GOT SERVER bc6073c1-2059-0d19-a398-b7a1bfe237b1::2a710461-fb9f-4bb5-bbaa-bd5bfcee4e0b @ 192.168.7.114:9200 RoPieeeJeff PROTOVER=1 RAATVER=1.1.38
04/14 15:26:15 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] connecting (attempt 1)
04/14 15:26:15 Debug: [easyhttp] [31] GET to https://api.roonlabs.net/porttest/1/myip returned after 65 ms, status code: 200, request body size: 0 B
04/14 15:26:15 Debug: [easyhttp] [30] GET to https://api.tidal.com/v1/users/38631927/subscription?countryCode=US returned after 96 ms, status code: 200, request body size: 0 B
04/14 15:26:15 Trace: [tidal/http] GET https://api.tidal.com/v1/users/38631927/subscription?countryCode=US => Success
04/14 15:26:15 Trace: [tidal] transition loginstatus from StartupWithCredentials to LoginSucceeded
04/14 15:26:15 Info: [broker/locations] updating location Tidal:Name=TIDAL:Id=a2bc918b-81fb-abc3-f24b-19bcfed910a2
04/14 15:26:15 Info: [broker/locations] media availability: Tidal:Name=TIDAL:Id=a2bc918b-81fb-abc3-f24b-19bcfed910a2 is online
04/14 15:26:15 Debug: [easyhttp] [29] POST to https://api.roonlabs.net/roonmobile/1/cores/announce returned after 145 ms, status code: 200, request body size: 1 KB
04/14 15:26:15 Info: [broker/locations] adding storage location: Tidal:Name=TIDAL Library:Id=672610e9-875a-d987-20f5-14b4e00ed155
04/14 15:26:15 Info: [broker/locations] media availability: Tidal:Name=TIDAL Library:Id=672610e9-875a-d987-20f5-14b4e00ed155 is online
04/14 15:26:15 Info: [music/storage] Loading storage backend My Tidal Library
04/14 15:26:15 Info: [library] retaining 35408 tracks for storage backend 672610e9-875a-d987-20f5-14b4e00ed155 (My Tidal Library)
04/14 15:26:15 Info: [library] retaining 0 auxfiles for storage backend 672610e9-875a-d987-20f5-14b4e00ed155 (My Tidal Library)
04/14 15:26:15 Trace: [tidal] beginning change detection
04/14 15:26:15 Trace: [tidal/storage] sync force=True
04/14 15:26:15 Trace: [tidal/storage] scan 1: starting
04/14 15:26:15 Info: [devicedb] [autodetect] Match w/Candidates DeviceAutodetectData[Type=Cast Model=Chromecast] => Chromecast (Candidates = Chromecast | Chromecast (1st Gen))
04/14 15:26:15 Info: [cast] discovered CastDevice[DeviceId=Chromecast-5386133bb6e7dd8155323b727bb3883d._googlecast._tcp.local, Name=Chromecast, Address=192.168.7.214]
04/14 15:26:15 Debug: [easyhttp] [36] GET to https://api.tidal.com/v1/users/38631927/favorites?countryCode=US returned after 42 ms, status code: 200, request body size: 0 B
04/14 15:26:15 Debug: [easyhttp] [33] POST to https://api.roonlabs.net/roonmobile/1/cores/announce returned after 165 ms, status code: 200, request body size: 1 KB
04/14 15:26:15 Debug: [easyhttp] [34] POST to https://api.roonlabs.net/roonmobile/1/cores/announce returned after 168 ms, status code: 200, request body size: 1 KB
04/14 15:26:15 Info: [mobile] GOT HTTP API /portverify/f24ee6cf-9bc3-44e1-bdc7-58b3b8afd3da
04/14 15:26:15 Trace: [mobile] Got PortVerify Request from_guid=f24ee6cf-9bc3-44e1-bdc7-58b3b8afd3da
04/14 15:26:15 Trace: [mobile] Returning guid for verification: 35a5b931-a2a6-4309-8e4f-91b599959326
04/14 15:26:15 Info: [mobile] GOT HTTP API /portverify/a1aca2c4-d2de-4be8-a477-fc63d4be5277
04/14 15:26:15 Trace: [mobile] Got PortVerify Request from_guid=a1aca2c4-d2de-4be8-a477-fc63d4be5277
04/14 15:26:15 Trace: [mobile] Returning guid for verification: 7875077c-bfef-4c7d-9ec5-8c5c7dfa4a1f
04/14 15:26:15 Debug: [easyhttp] [32] POST to https://api.roonlabs.net/porttest/1/port/check returned after 340 ms, status code: 200, request body size: 743 B
04/14 15:26:15 Debug: [easyhttp] [35] POST to https://api.roonlabs.net/porttest/1/port/check returned after 269 ms, status code: 200, request body size: 743 B
04/14 15:26:15 Trace: [mobile] [remoteconnectivity] {"logs":[["4/14/2023 7:26:15 PM getting local InterNetwork address for external connections from OS","got InterNetwork address for google.com: 142.251.16.105","local InterNetwork address: 192.168.7.137"],"4/14/2023 7:26:15 PM Got local address of 192.168.7.137 for interface that connects to the external world\n",["4/14/2023 7:26:15 PM getting local InterNetworkV6 address for external connections from OS","didn't find an InterNetworkV6 host entry for www.google.com"],["4/14/2023 7:26:15 PM getting external ip address from Roon webserver","4/14/2023 7:26:15 PM Got external ip address from Roon controlled web service: 24.aaa.bbb.ccc"],["4/14/2023 7:26:15 PM trying upnp port mapping for ipv4, gatewayip: 192.168.7.1","4/14/2023 7:26:15 PM Attempting to get external IP from router","4/14/2023 7:26:15 PM Found UPnP service with ControlUri: http://192.168.7.1:1900/ipc","4/14/2023 7:26:15 PM Got external IP from router: 24.aaa.bbb.ccc","4/14/2023 7:26:15 PM Overall status of attempt get external address from router: Success\n",["4/14/2023 7:26:15 PM delete UPnP port opening start","4/14/2023 7:26:15 PM UPnP request to get list of port mappings failed, message: <?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Body>\n <s:Fault>\n <faultcode>s:Client</faultcode>\n <faultstring>UPnPError</faultstring>\n <detail>\n <UPnPError xmlns=\"urn:schemas-upnp-org:control-1-0\">\n <errorCode>602</errorCode>\n <errorDescription>Optional Action Not Implemented</errorDescription>\n </UPnPError>\n </detail>\n </s:Fault>\n </s:Body>\n</s:Envelope>\n \n","4/14/2023 7:26:15 PM Overall status of attempt to delete existing port mappings: UnexpectedError\n"],"4/14/2023 7:26:15 PM UPnP port opening start","4/14/2023 7:26:15 PM Found UPnP service with ControlUri: http://192.168.7.1:1900/ipc","4/14/2023 7:26:15 PM Overall status of attempt to set ipv4 port forwarding with UPnP: UPnP ActionResult={\r\n}\r\n"],["4/14/2023 7:26:15 PM check external ip address 24.aaa.bbb.ccc start","4/14/2023 7:26:15 PM Request from Roon controlled server to Roon Core at https://24.aaa.bbb.ccc:55002 was successful","4/14/2023 7:26:15 PM Overall status of attempt to verify port opening: Success\n"]],"diagnostics":{"ipv4_connectivity":{"status":"Success","status_code":200,"error":""},"external_ip":{"actual_external_ip":"24.aaa.bbb.ccc","actual_external_ipv6":"null","router_external_ip":"24.aaa.bbb.ccc"},"natpmp_autoconfig":{"status":"NotFound"},"upnp_autoconfig":{"server_ip":"192.168.7.1","found_upnp":true}}}
04/14 15:26:15 Info: [transport/zonedisplay] Zone display registered: CastDevice[DeviceId=Chromecast-5386133bb6e7dd8155323b727bb3883d._googlecast._tcp.local, Name=Chromecast, Address=192.168.7.214]
04/14 15:26:15 Debug: [easyhttp] [37] POST to https://api.roonlabs.net/roonmobile/1/cores/announce returned after 164 ms, status code: 200, request body size: 1 KB
04/14 15:26:15 Info: [mobile] GOT HTTP API /hello
04/14 15:26:16 Debug: [easyhttp] [38] GET to https://api.roonlabs.net/roonmobile/1/cores/6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3/keypairs/api/02b4a444-edc9-4f6c-b4dc-756827977a40 returned after 186 ms, status code: 200, request body size: 0 B
04/14 15:26:16 Trace: [mobile] Got Hello Request body={"coreId":"6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3"}
04/14 15:26:16 Trace: [raatserver] [sood] Refreshing device list
04/14 15:26:16 Trace: [library] finished with 46601 dirty tracks 3555 dirty albums 28299 dirty performers 24228 dirty works 36794 dirty performances 857 dirty genres 1 dirty tags 37 dirty countries 1 dirty periods 2 dirty forms 1446 dirty places 513 dirty creditroles 883 dirty labels 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 35408 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 129142 changed objects
04/14 15:26:16 Trace: [music/searchindex] [search-index] removed in 6ms: 915 albums, 0 tracks, 0 works, 0 performers, 0 labels, 836 genres
04/14 15:26:17 Trace: [music/searchindex] [search-index] added in 888ms: 3555 albums, 35408 tracks, 14847 works, 24617 performers, 883 labels, 836 genres
04/14 15:26:17 Trace: [dbperf] flush 0 bytes, 0 ops in 26 ms (cumulative 0 bytes, 0 ops in 7696 ms)
04/14 15:26:17 Trace: [library] endmutation in 1928ms
04/14 15:26:17 Trace: [tidal/http] GET https://api.tidal.com/v1/users/38631927/favorites?countryCode=US => Success
04/14 15:26:17 Trace: [tidal/storage] got timestamps
04/14 15:26:17 Info: favorite albums cached ts 3/21/2023 8:48:10 PM result ts 3/21/2023 8:48:10 PM
04/14 15:26:17 Info: favorite tracks cached ts 3/22/2022 10:55:00 PM result ts 3/22/2022 10:55:00 PM
04/14 15:26:17 Info: favorite playlists cached ts 10/12/2019 2:50:28 PM result ts 10/12/2019 2:50:28 PM
04/14 15:26:17 Info: playlists cached ts 3/2/2020 12:40:55 AM result ts 3/2/2020 12:40:55 AM
04/14 15:26:17 Trace: [tidal/storage] will scan favorite playlists
04/14 15:26:17 Trace: [tidal/storage] will scan playlists
04/14 15:26:17 Trace: [library] endmutation in 16ms
04/14 15:26:17 Trace: Loading credits JSON from C:\Users\jeffr\AppData\Local\RoonServer\Application\200001244\credit_roles.json
04/14 15:26:17 Info: [library/albumdetails] found 1 ingroup alternates, 0 other alternates
04/14 15:26:17 Info: [library/albumdetails] Created album details screen for LibraryAlbum[785199, Damien Jurado - Rehearsals For Departure]
04/14 15:26:17 Info: [library/albumdetails] 79004d5730303030303438383032, 79004d5230303034353832353935, 79004d5230303033383738333136, 79004d5230303033303034323734, 79004d5230303030393530383732, 3e0160d0ee2deddd893fb439d2022fd7edbc, 3e01250c20593b86ff4e8ded68c822272668, a6003335303930373032, a6003736373532363535, c8006d7074793078716c766b347763, c80030303938373837303434303635, cd00437049747a2d576b6177375944424f425143
04/14 15:26:17 Debug: [easyhttp] [41] POST to https://api.roonlabs.net/metadata/1/albums/translate?c=tidal-us returned after 77 ms, status code: 200, request body size: 406 B
04/14 15:26:17 Debug: [easyhttp] [39] GET to https://api.tidal.com/v1/users/38631927/favorites/playlists?countryCode=US&offset=0&limit=50 returned after 597 ms, status code: 304, request body size: 0 B
04/14 15:26:17 Info: [library/albumdetails] found 1 streaming service alternates
04/14 15:26:17 Trace: [tidal/http] GET https://api.tidal.com/v1/users/38631927/favorites/playlists?countryCode=US&offset=0&limit=50 => Success
04/14 15:26:17 Warn: null SortEnv language. Defaulting to current culture.
04/14 15:26:17 Debug: [easyhttp] [42] GET to https://api.tidal.com/v1/playlists/c9f74da3-3285-4d33-bed2-bab8fe8794e4/tracks?countryCode=US&offset=0&limit=50 returned after 57 ms, status code: 304, request body size: 0 B
04/14 15:26:17 Trace: [music/query] performing album query
04/14 15:26:17 Debug: [easyhttp] [43] POST to https://api.roonlabs.net/browse/1/works/trackCounts?c=tidal-us returned after 86 ms, status code: 200, request body size: 287 B
04/14 15:26:17 Trace: [music/query] query returned 5 Sooloos.Broker.Api.AlbumLite(s)
04/14 15:26:17 Trace: [music/query] query returned 0 Sooloos.Broker.Api.AlbumLite(s)
04/14 15:26:18 Trace: [tidal/http] GET https://api.tidal.com/v1/playlists/c9f74da3-3285-4d33-bed2-bab8fe8794e4/tracks?countryCode=US&offset=0&limit=50 => Success
04/14 15:26:18 Debug: [easyhttp] [45] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/timeline/albums?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 123 ms, status code: 200, request body size: 0 B
04/14 15:26:18 Debug: [easyhttp] [50] GET to https://api.roonlabs.net/metadatatext/1/blobs?objectId=121:0:MW0000048802&type=review&sourceLangs=Rovi-albums:en,Wikipedia:en,Rovi-artists:en,Rovi-compositions:en&c=tidal-us&contentPreferences=avoidMqa returned after 102 ms, status code: 200, request body size: 0 B
04/14 15:26:18 Debug: [easyhttp] [46] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/albums/morefromcollaborators?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 124 ms, status code: 404
04/14 15:26:18 Debug: [easyhttp] [47] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/similar/albums?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 161 ms, status code: 404
04/14 15:26:18 Debug: [easyhttp] [52] POST to https://api.roonlabs.net/metadata/1/tracks/media?c=tidal-us&deps=none returned after 83 ms, status code: 200, request body size: 342 B
04/14 15:26:18 Debug: [easyhttp] [48] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/performers/similar?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&languages=en,latn returned after 215 ms, status code: 200, request body size: 0 B
04/14 15:26:18 Debug: [easyhttp] [44] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/albums/new?profile=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 250 ms, status code: 200, request body size: 0 B
04/14 15:26:18 Trace: [library] finished with 1 dirty performers 1 dirty places 0 clumping tracks, 0 clumping auxfiles 0 compute tracks, 0 deleted tracks, 0 tracks to (re)load, 0 tracks to retain, 0 auxfiles to (re)load, 0 auxfiles to retain, and 1 changed objects
04/14 15:26:18 Debug: [easyhttp] [51] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/recommended/albums?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 175 ms, status code: 200, request body size: 0 B
04/14 15:26:18 Trace: GetImageData[Remote](id=162480 spec=1by1_128 key=gjgjaaaa) => got from cache overalltime=0ms
04/14 15:26:18 Trace: GetImageData[Remote](id=162480 spec=1by1_128 key=gjgjaaaa) => got from cache overalltime=1ms
04/14 15:26:18 Trace: GetImageData[Remote](id=27499 spec=1by1_128 key=rrobaaaa) => got from cache overalltime=0ms
04/14 15:26:18 Debug: [easyhttp] [40] GET to https://api.tidal.com/v1/users/38631927/playlists?countryCode=US&offset=0&limit=50 returned after 1098 ms, status code: 304, request body size: 0 B
04/14 15:26:18 Trace: [tidal/http] GET https://api.tidal.com/v1/users/38631927/playlists?countryCode=US&offset=0&limit=50 => Success
04/14 15:26:18 Debug: [easyhttp] [53] GET to https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=0&limit=50 returned after 46 ms, status code: 304, request body size: 0 B
04/14 15:26:18 Trace: [tidal/http] GET https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=0&limit=50 => Success
04/14 15:26:18 Debug: [easyhttp] [54] GET to https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=50&limit=50 returned after 61 ms, status code: 304, request body size: 0 B
04/14 15:26:18 Trace: [tidal/http] GET https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=50&limit=50 => Success
04/14 15:26:18 Debug: [easyhttp] [55] GET to https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=100&limit=50 returned after 50 ms, status code: 304, request body size: 0 B
04/14 15:26:18 Trace: [tidal/http] GET https://api.tidal.com/v1/playlists/ddf3a44f-4227-44c8-a24a-97fe54a0862c/tracks?countryCode=US&offset=100&limit=50 => Success
04/14 15:26:18 Debug: [easyhttp] [56] POST to https://api.roonlabs.net/metadata/1/tracks/media?c=tidal-us&deps=none returned after 85 ms, status code: 200, request body size: 1 KB
04/14 15:26:18 Trace: [tidal/storage] scan 1: finished
04/14 15:26:18 Trace: [tidal/storage] scan 1: OnLibraryUpdated CachedLibrary=Sooloos.Broker.Tidal.TidalCachedLibrary LibraryUpdated=System.Action`2[Sooloos.Broker.Tidal.TidalStorageBackend+Scan,Sooloos.Broker.Tidal.TidalCachedLibrary]
04/14 15:26:18 Info: [tidal/storage] Scan reported Library updated LastScanned=4/14/2023 12:09:26 PM
04/14 15:26:18 Info: [tidal/storage] Library for userid 38631927 has:
04/14 15:26:18 Info: [tidal/storage] 11 tracks
04/14 15:26:18 Info: [tidal/storage] 2635 albums
04/14 15:26:18 Info: [tidal/storage] 1 favorite playlists
04/14 15:26:18 Info: [tidal/storage] 1 playlists
04/14 15:26:18 Trace: [tidal/storage] sync completed successfully in 3407ms
04/14 15:26:20 Trace: [raatserver] [sood] Refreshing device list
04/14 15:26:20 Debug: [easyhttp] [57] POST to https://api.roonlabs.net/discovery/1/register returned after 140 ms, status code: 200, request body size: 1 KB
04/14 15:26:20 Trace: [inetdiscovery] registered 1 devices, 5 services
04/14 15:26:20 Debug: [easyhttp] [49] GET to https://api.roonlabs.net/discover/1/albums/121:0:MW0000048802/albums/morefromgenre?profileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34&c=tidal-us&contentPreferences=avoidMqa returned after 2865 ms, status code: 404
04/14 15:26:21 Trace: [appupdater] initial check for updates
04/14 15:26:21 Trace: [remoting/remotingserverv2] SENT NONFINAL DistributedBroker.UpdatesChangedResponse={ IsSupported=True WasJustUpdated=False Status='Checking' HasChangeLog=False CurrentVersion={ MachineValue=200001244 DisplayValue='2.0 (build 1244) production' Branch='production' } }
04/14 15:26:21 Debug: [base/updater] Checking for updates: https://updates.roonlabs.com/update/?v=2&serial=F2A294CB-3AE8-455B-BF83-BF3FC8754D22&userid=1e2ca65d-c05e-4ac2-9eb9-039411694b91&platform=windows64&product=RoonServer&branding=roon&curbranch=production&version=200001244&branch=production&coredeviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&deviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&osversion=Windows+11&os64bit=true
04/14 15:26:21 Debug: [easyhttp] [58] GET to https://updates.roonlabs.com/update/?v=2&serial=F2A294CB-3AE8-455B-BF83-BF3FC8754D22&userid=1e2ca65d-c05e-4ac2-9eb9-039411694b91&platform=windows64&product=RoonServer&branding=roon&curbranch=production&version=200001244&branch=production&coredeviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&deviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&osversion=Windows+11&os64bit=true returned after 317 ms, status code: 204, request body size: 0 B
04/14 15:26:21 Debug: [appupdater] Update not needed
04/14 15:26:21 Trace: [remoting/remotingserverv2] SENT NONFINAL DistributedBroker.UpdatesChangedResponse={ IsSupported=True WasJustUpdated=False Status='UpToDate' HasChangeLog=False CurrentVersion={ MachineValue=200001244 DisplayValue='2.0 (build 1244) production' Branch='production' } }
04/14 15:26:22 Info: [stats] 6776mb Virtual, 1452mb Physical, 1275mb Managed, 2383 Handles, 194 Threads
04/14 15:26:25 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] client connection failed. Retrying in 500ms
04/14 15:26:25 Debug: [easyhttp] [59] POST to https://api.roonlabs.net/device-map/1/register returned after 85 ms, status code: 200, request body size: 4 KB
04/14 15:26:25 Trace: [devicemap] device map updated
04/14 15:26:25 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] connecting (attempt 2)
04/14 15:26:27 Info: [library] saved recent ProfileId=9937205b-3170-4df8-aac5-5d8c8f1b7d34 Time=4/14/2023 7:26:26 PM DataType=album Type=long_nav MetadataId=9830265 ContentId=9830265 LibraryId=785199 Text= Genre=
04/14 15:26:28 Trace: [remoting/remotingserverv2] SENT NONFINAL DistributedBroker.UpdatesChangedResponse={ IsSupported=True WasJustUpdated=False Status='Checking' HasChangeLog=False CurrentVersion={ MachineValue=200001244 DisplayValue='2.0 (build 1244) production' Branch='production' } }
04/14 15:26:28 Debug: [base/updater] Checking for updates: https://updates.roonlabs.com/update/?v=2&serial=F2A294CB-3AE8-455B-BF83-BF3FC8754D22&userid=1e2ca65d-c05e-4ac2-9eb9-039411694b91&platform=windows64&product=RoonServer&branding=roon&curbranch=production&version=200001244&branch=production&coredeviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&deviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&osversion=Windows+11&os64bit=true
04/14 15:26:28 Debug: [easyhttp] [60] GET to https://updates.roonlabs.com/update/?v=2&serial=F2A294CB-3AE8-455B-BF83-BF3FC8754D22&userid=1e2ca65d-c05e-4ac2-9eb9-039411694b91&platform=windows64&product=RoonServer&branding=roon&curbranch=production&version=200001244&branch=production&coredeviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&deviceid=6c642a42-7ccf-41a4-9f6c-1a5a21e96cc3&osversion=Windows+11&os64bit=true returned after 159 ms, status code: 204, request body size: 0 B
04/14 15:26:28 Debug: [appupdater] Update not needed
04/14 15:26:28 Trace: [remoting/remotingserverv2] SENT NONFINAL DistributedBroker.UpdatesChangedResponse={ IsSupported=True WasJustUpdated=False Status='UpToDate' HasChangeLog=False CurrentVersion={ MachineValue=200001244 DisplayValue='2.0 (build 1244) production' Branch='production' } }
04/14 15:26:35 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] client connection failed. Retrying in 750ms
04/14 15:26:36 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] connecting (attempt 3)
04/14 15:26:37 Info: [stats] 6760mb Virtual, 1112mb Physical, 715mb Managed, 2338 Handles, 190 Threads
04/14 15:26:45 Debug: [easyhttp] [61] POST to https://api.roonlabs.net/discovery/1/query returned after 148 ms, status code: 200, request body size: 74 B
04/14 15:26:46 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] client connection failed. Retrying in 1125ms
04/14 15:26:47 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] connecting (attempt 4)
04/14 15:26:52 Info: [stats] 6760mb Virtual, 1112mb Physical, 718mb Managed, 2338 Handles, 190 Threads
04/14 15:26:57 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] client connection failed. Retrying in 1687ms
04/14 15:26:59 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] connecting (attempt 5)
04/14 15:27:07 Info: [stats] 6752mb Virtual, 1112mb Physical, 720mb Managed, 2338 Handles, 188 Threads
04/14 15:27:09 Trace: [raatserver] [RaatServer RoPieeeJeff @ 192.168.7.114:9200] client connection failed. Giving up
04/14 15:27:09 Trace: [raat] [sood] Refreshing device list
