RoPeee Reboot Loop Help
When I go to my RoPeee web page it says to reboot. I reboot and it says to reboot. its in a loop. Help please
Can you send me feedback?
Harry I keep getting this screen, what "feedback do you want?
Go to the ‘advanced’ tab. Over there is a button ‘Send Feedback’.
Sorry Harry sent feedback 0d3698278a30c9ad
Having same issue trying to upgrade from 386 to latest version. Have gone through reboot cycle several times.
Feedback ce4fed5407135ab1
Thanks … Tim
Hi @Richard_Thorpe and @anon97951896,
Unfortunately you have both the same situation (corruption in the package db), which I don’t know how to fix remotely… I’m afraid a reflash is required.
@anon97951896 your logs are flooded with ‘undervoltage’ reports. It might be good to look at your power supply.
@spockfish
I will reflash and swap power supply.
Tim
Thanks Harry reflashed everything good.
