Ok can you do the test as described above? Start playing audio and wait for a few minutes before sending feedback? No need to play / pause or anything, just some audio for 2 minutes.
Sent after about 20 minutes of playing:
Logs have been sent to RoPieee HQ with unique identifier 96a823c44f94276a
@spockfish
When I first noticed the issue I rebooted ROCK.
Rock is running now for 2 days, 23 hours, 45 minutes, 9 seconds.
Thanks for the feedback. I now know for sure it’s the extension that’s not being updated.
The Web Controller also has a sync issue.
The screen seems frozen, even when I refresh the screen, then once and a while it changes when I refresh the page but it is always behind.
Very valuable feedback!
This might turn out to be ROCK related…
What happens if you restart roon server?
I have had this a few times to. I also run ROCK, not sure really what’s triggering it.
Restarted Roon Server
Everything back to normal on the display and on the Web Controller page (after a refresh).
ok. it’s time for me to contact Roon HQ.
I have the same problem. When i click reload extension, it changes, but the play bar freeze a few seconds after. And the display dont change. I run Roon core on a Asrock beebox in windows 10.
And what is this box for?
If you set the “Update Schedule” to a schedule, the “Next Sync” tells you when that time is. You are currently set to update on boot, so the update time is unknown.
Ok. Thanks. I set it to get the beta version. Maybe the album info will update…?
