RoPieee does not identify wireless network interface
I recently set up RoPieeeXL v3.113 on my RPi 4 (Model B Rev 1.2).
I got it running over ethernet but I’m having trouble enabling the wireless connection.
Here are the steps I’m taking:
Navigate to Ropieee → Network → Wireless (shows enabling hardware interface)
However, from here, I’m unable to select or detect a hardware interface. If I select “scan” it just spins endlessly.
I’ve tried enabling the hardware and rebooting several times, then attempting to configure, but this unfortunately has not helped.
Any suggestion as to how to resolve this would be greatly appreciated!
Thanks in advance,
JP
You might try submitting the logs via the feedback option on the Advanced tab. Harry may be able to see some indication of the problem.
