I would love some description on what features are available by touchscreen now. Is it a display, next-last track thing? Does it access any of the roon control stuff? Not trying to put anything down, I’ve just not seen anything that explains all you can do.
Harry, thank you for this. Got my basic pi running with an Audioquest Dragonfly last night and it is a fantastic piece of work. And since I have Ethernet ports all around, a wonderful portable way to bring headphones in the house anywhere I go. I hook a powerbank up to the USB power and boom! Roon-enabled headphones.
The documentation is lacking a bit. True that. It’s just not the most exciting piece to work on, but it’s on my list.
Anyways, the display shows current track information and a few basic controls: play/pause, forward/next. Furthermore you can select shuffle, loop and auto radio.
I use the next track button frequently and often back button too, especially when listening to tidal playlists I have the lcd unit on my desk.
Maybe one thing that might be worth adding is a favorite button / indication and do to be able to add a track or remove it as a favorite without having to find a remote client! Not sure if that’s doable in the api with roon but handy for sure thinking about it.
If you would like, maybe I can try putting something together; I wouldn’t do it without your assent. But the only way things like this progress is volunteers step up.
And let me say again. Thank you for doing this. It’s really a great service to the community. And it really works well.
I was testing the latest RoPieee as well on a Pi here and it was working good so far.
I noticed 2 things (click to expand):
[details=Allo DigiOne was not playing when USB output is activated]
I have no clue if this is supposed to be that way. But there was no sound when it was activated[/details]
[details=I disliked the Zone configuration] I am not sure if this has been brought up already.
(Ignore this if this is the case )
You could also create a DropDown in the Roon Extension to select the zone. Or even better: have a zone icon in the GUI on the Touchscreen where you can select the zone.[/details]
I like both options. The former for those that don’t touch the screen (i.e. use it as ‘now playing’ display only) and the latter for those that do touch the screen.
If you’re on stable then you need to check if you’ve got version ‘056-1’ (check the information tab).
You can then switch player screen by clicking the covert art. That will switch you to the new screen with the new controls. Clicking again brings you back to the ‘original’ screen. RoPieee remembers which screen you’re using.
Could you slow down the song title scrolling a little bit more?
The album and artist scrolling speeds are slower and are great but song title at the very top is still a bit too quick, especially for the longer titles.
I’d say it is not enough power. The specifications are given on your linked kickstarter page:
Input voltage 36-56V, output voltage 5V, output current 10-1300mA, max output power 6.5W
I just googled for the requirements of Pi + Touchscreen and found this on pimoroni:
How much power does it use?
The screen on its own pulls between 450 and 470mA.
Combined with a Pi 2 with an Ethernet connection and running stress -c 100 to load the CPU brings it up to 925mA.
Basically, we recommend using an official Pi 2A power supply, you'll need it!
