Hello guys…i am happy user of roon. So i used to listen music with it via usb to dac.
For practical reason i want to play through my pi with ropieee. I do it before days but the signal was cutting for 2seconds and after comes back for 2seconds.
Beacuse i use some filters (both ifi iusb and igalvanic) i am thinking that maybe the rpi can’t give much ma. I read that rpi gives max 1200ma for all usb ports. I don’t have any device to the other ports.
Is there a way to make it work?! Is there a way to give more usb power output?!maybe is there other problem with ropieee that cuts the signal?! With my macbook i don’t have that signal issue.
I am searching for a solution with that i have in order to save some money.
Thanx
