I have rearranged my network cabling so now Roon Core and RoPieee are directly connected to the Broadband router and music lib on the NAS is connected via one switch only to the router.
This hasn’t helped fully, but generally it’s hours between losing connection now when it was minutes before. This happened already in post 5 of the thread though, long before my rearranged cabling and I don’t understand what caused it since nothing really was changed after I moved RoPieee back…
The usual stuff: timeouts on the server.
And you’re on wifi
Anyways, not much I can do about it right now.
I’ll ad a note to my list to see if I can make it a little bit more resilient to these timeouts.
Hmm… I might be onto something.
“you’re on wifi” - I’m assuming that was for @anon1796887 since I have wired only (except Roon remote clients.) Both Core and RoPieee are connected to LAN outputs on the broadband router.
It´s same with wired connection, first thing I tested to use wired connection and after I find out that same happens with that I swapped back to wireless. Definetely problem is in side of Raspberry not the network.
I finally got around to doing this. I had no network errors (that I noticed) up until last night.
Here is the identifyer: c796646f6eae46a7
So … does this mean it hasn’t occured anymore or does this mean you saw it last night and sent the feedback after that?
I’ve pushed a minor update to the beta channel that might make the extension a little bit more robust: if you see it happening again you could switch to the beta channel to check it out.
I had not seen any connection issues until the evening before I sent the report. But I had much lower listening activity.
There was an update pending this morning and I installed it.
I will try the beta if I see more connection interruptions.
Thanks.
The connection failures are appearing less frequently after I rearranged cabling so both Roon and RoPieee are connected directly to the broadband router from my internet provider. It seems to lose connection momentarily when coming to the end of playlists playing to the zone that it’s endpoint for, but other than that it is quite stable now. Still I think that it should be possible to add some switches in between without losing stability - especially considering that it’s all wired gigabit ethernet.
Now it’s not happening often enough to be used as a testbed but if you like @spockfish I can load the beta and check if that gets rid of the loss of connection after a playlist comes to an end.
Yes that would be interesting.
So you’re saying that it is always happening in the case of an ‘end of playlist’ event?
I was only observing the status twice before and then it changed from Running (nnn) to Running without minute indication and when it started showing Running(nnn) again the minutes had started from 0. Then I tried it again and didn’t get the same result so it’s happened two out of three times here. I’m currently loading the beta (version 2.5.4.5) to see if that makes any difference, but it may have to wait until after the weekend since I’m quite busy the next few days.
I played one album with beta software and Running (nnn) didn’t reset at end-of-playlist - i.e. connection remained. But since there’s so few tries I’m not sure what conclusions one can draw from it. I’ll test some more in a few days.
I have been running this beta 2.546 and problem persist still
feedback : 9d0ce560f30ce53c
Noticed that at roon server discovered extensions dissappears most of the times when you get the error at roopie display.
Continuously time outs reported when connecting to Roon core.
Nothing much I can do about it, but I would definitely suggest you investigate your infrastructure as the time-outs are rather frequent.
There is nothing to that I can do with network, if I run both connected ( Roon core and roopie) directly to my Cisco Catalyst 9300 switch I get also those errors. Maybe problem is at Raspberry side (power supply etc…?) I tested also Dietpi as a display, that works without problems, but it´s not as nice looking as roopie.
I’m also seeing this on 2.535. I’ve sent feedback: de24d75d1d64fec1.
This is a fairly new build of an rpi 3 b+ with the official touchscreen. It’s been stable for a couple of weeks but in the last day has started frequently complaining about connection quality and then rebooting. The rpi is connected via Ethernet to a Ubiquiti Unifi switch which is also powering the rpi via poe. The Roon core is a nucleus which is also hard wired to the same switch.
Edited to add: this is a display only, and the problem only seems to happen when there is no music playing on the zone it is displaying.
For me it happens most frequently at end of playlist but it has also lost contact when I’m browsing my library to select what to listen to. If I just leave it it almost never lose connection anymore.
Hello spockfish,
Things were good until today.
I generated a feedback log with ID: c81acbe44b6ba643
Just so you have feedback.
For me no issue. I will just reboot and things will be fine again for a couple of days.
Cheers.
This is happening to me every 30 seconds on both wifi and ethernet. RPI 3 with official display connect to Roon ROCK on NUC.
I just sent feedback: 4033f15f1108e89e
My symptom is the same as others reported here. I also observe the remote control extension leaving and reappearing in the extensions screen. In my case, it is almost exactly every 30 seconds that this occurs. Issue occurs on ethernet or wifi.
