Hi all,
after the latest release update for ropieee I can’t activate my ropieee with Digi2Pro HAT as Roon Bridge in Roon because it is not shown as device in the audio section.
I can see the Ropieee in the Info section with the correct host name but it shows not up in the audio section.
the Digi2 Pro is activated in the Ropieee web Interface
all devices in the same sub net
all devices connected with ethernet (also tested with WiFi connection but same problem)
Configurtation
Nucleus
Raspberry Pi Pi 4 Model B Rev 1.4
HiFiBerry Digi2Pro via S/PDIF connected to MAN 301 DAC
all devices updated to the earliest release
any idea what i can do to solve the problem?
Could you call up that device via its Internet (IP) Address and check if your Digi2Pro HAT is correctly activated? Menu “AUDIO”, then “Audio HAT”
If NOT, scroll through that list, find and activate that Digi2PRO HAT and then SAVE and REBOOT
The HiFiBerry Digi2Pro is selected and I have rebooted the system several times.
Still is RoPieee visible in the Info section but not in the Audio section.
Have you rebooted your ROPIEEE AND your NUCLEUS to be on the safe side?
Can you send me feedback?
I have rebooted both RoPiee and Nucleus, still the same.
Send Harry “feedback” please! Go to the “ADVANCED” tab in your ROPIEEE device by clicking at its IP adress then click the green button SEND FEEDBACK on the bottom right , which generates after a bit of wait a unique identifier which you should copy/paste here, so Harry will have a chance to look…
Hello Harry,
Here is the unique identifier as requested by Dr. Klaus.
38231f976e0d4513
Have send the UI to Harry 2 min ago
38231f976e0d4513
Hi @Crooner ,
For some reason your HAT is not identified (and not even seen!).
Can you make sure it’s properly connected and so on? That’s the only thing I can think of… Or the device is completely dead in the water.
Thanks for your effort.
After disconnecting - connecting everything and several time power off / on the Ropieee shows up in Audio and everything woks now.
My feeling is that something with the power supply was the reason, but not sure.
Thanks again.
Crooner
