I see in the https://ropieee.org/audio_hardware/ list, RoPieee is not compatible with the Digi2 Pro.
And indeed, it does not work.
Is it possible to do something about that? Or do I have to wait for an update and hope it’s added?
Which HAT did you try? You need to select the ‘Hifiberry Digi+ Pro’
YES!!!
I’m completely in love with RoPieee!
