Ropieee with remote control and display
I have assemblied a Ropieee endpoint : Raspberry Pi 3 Model B+ / HiFiBerry Digi+ Standard . It works fine, either Ethernet or WiFi.
Now I am looking for Display and remote control.
Some points are not clear !
Can I use a remonte control without using a display ?
On some topics on the forum one can understand that with a Ropieee it could be possible to ‘manage’ any zone. For example, does a Ropieee + remote control would allow to manage (pause, volume) of my SONOS zone ?
Thanks !
Either use the Official Raspberry Pi Display (requires a re-flash), or use Roon output display via html and any web browser.
Yes, these are completely separate pieces of functionality. The hardware remote can control any Roon Control Zone.
Thanks !
So, remote control is very interesting as a quick way to switch off/on sound when needed.
Yes. You can stop a track or adjust its volume.
