Ropieee now shows in Spotify, but still no sound when set to use either Hardware or Software.
I did notice however that, if I set volume to maximum then I do get sound. So I can either have no sound or full volume. Just need something in-between now
I have been using the Spotify interface to set the volume.
It is set at 25 initially matching the RopieeeXL config, but there is no sound at all at any volume level until set at maximum in the Spotify interface.
I have flashed the SD with ropieeexl and and switched it to the Beta version. When I do that and commit the changes it updates and restarts, and I can browse to it and see that it is Beta version 2.596. At that point I can select HAT for my audio output, but the hardware option for volume control is still disabled (I donāt know that enabling that is the goal, but that is the case), and I airplay level is still dependent on the Roon output volume setting.
I also see that there is a blue banner saying that there is an update for your device. When I try to apply that, after it has returned to the slowly blinking green light, I can no longer browse to the device, although nmap sees it on the network. Do I need the update or should something have changed with just the beta version of ropieeexl? Or am I very possibly doing something else wrong?
Iāve pushed an update to the beta channel.
There have been quite a few changes surrounding hardware mixer control in the Spotify client, so letās try this out.
Hmmm thatās strange, because you need the update on the beta channel to get this working.
When you apply the update (first it installs then it mentions that you need to reboot & install it), you will see another screen (the unit is being updatedā¦) etc. Did you see that information?
Update is being downloadedā¦ Do not turn the device off!
Then:
The update has been downloaded. Reboot to apply it.
Update in progressā¦ Donāt interrupt!
When the update has been applied the device will reboot once again.
Then I eventually (5-10 min) see the slowly blinking green light, but when I try to browse to ropieeexl.local I see:
This site canāt be reached
ropieeexl.locals server IP address could not be found.
And this time around I am unable to find it using nmap (Iām no expert so that could be me).
I did not change the network cabling throughout three completions of this process; it worked priot to updating and not afterwards.
Many thanks @spockfish - the last set of changes now have Spotify Connect working correctly with the Hifiberry DAC+/AMP2.
Thanks for persevering with this - much appreciated!
I tried running through the process with another RPi without any extra hardware - no hat. That one worked all the way through the update and I could set the volume controle for Shairplay to hardware. I mainly wanted to verify that my home network wasnāt screwing things up. I am now trying another RPi that has the same hat as the original to see if the device is the issue.
The original RPi is ready to try something else though.
Harry, I tried running through the process with a different RPi and Justboom Hat device and it worked!
The Roon output works as expected, the Roon Shairplay output now has volume control independent of the Roon output, and Pandora through an iphone or ipod Airplay also works correctly. Exactly what I was looking for.
Now Iām going to look at the particular RPi and Hat combination that is not working and see if I can figure that out. If you have any suggestions I would welcome them, but for your part, mission accomplished and thanks again for your help and contribution.
