Version 1.8 (build 1021)
Ropieeexl 2022.06.4 (0459) on Raspberry Pi 4 version 1.5
Sent identifier 9282bdfbbb6f22f1
less than 200
I setup a new Raspberry Pi 4 using RopieeeXL. I installed the hifiberry digi+ pro hat. Installed software with ethernet and setup per instructions. I also setup airplay and Spotify connect. The ropieee audio zone does not show. Airplay and spotify does but there is no sound. I have tried output to coax and optical, no sound. I did change setting to usb out and it works fine. Output is sent to the Denafrips Ares II. I sent log. Thank you for looking at this.
Steven W
