I am having a similar problem. Running ROCK on a NUC and suddenly none of my remotes can connect. Also had this experience:
Just a quick fyi: I’ve been able to get Roon to occasionally open (maybe 1/10 times) and it comes up with ‘no audio devices found’.
Sounds like you had a corrupted db which was backed up ( a known issue) choosing an older one gave you an un-corrupted db hence success.
Maybe review your back up frequency, I do alternate days , save 20
Good luck, glad you won, eventually
dylan
(Dylan Caudill)
August 31, 2021, 5:26pm
3
Hi @Christopher_Pastore , can you try this:
Exit out of Roon/Roon Server
Navigate to your Roon Database Location - Database\Registry\Core
Locate your tidal_account file and delete it
Try to start Roon again
If you’re still seeing issues after that, please use the directions found here and send us over a set of logs using a shared Dropbox link (or any other file sharing service). Thanks!
noris
Closed
April 7, 2025, 9:30pm
4
