Am I correct to assume that the main advantages of a NUC for Roon core is the price & low noise(fanless)?
My thinking is that I can put a regular pc in the attic and run Roon core on that. I can get a regular pc for a good price but NUCs are a little more money in my country.
There are lots of good reasons to run ROCK - minimal management required being the biggest. But, Roon will only support ROCK on approved NUCs. You may be able to get ROCK running on a regular PC (aka MOCK), but you lose Roon support and may run into some headaches. Of course, you can certainly accomplish what you want to do by running RoonServer on your regular PC running Windows or Linux. Just make sure your regular PC is powerful enough to do so.
Great, if there is a perception that there is an SQ difference, then I wouldn’t be inclined to agree. In which case, it appears that running Core on a standard Windows based PC is great option.
I had nothing but problems running on a Dell XPS 15 i7 with 32GB RAM. It was my general purpose laptop doing other things, so that was part of the problem. Also used WIFI for a while. Nucleus has been FLAWLESS for 8 months.
I was up and running in about a half hour including time to sip tea and look over what I was doing. I copied my music over in about 6 hours. And it has been flawless.
Before that I was doing the demo on a ten year old Mac mini which was also flawless for the 2-3 weeks I was demoing before committing and buying a NUC.
The huge plus for me with the NUC is I don’t have yet another machine to feed and water. I already have too many boxes to admin in my life.
I see where you are coming from however I have a CCTV software running on Win PC for last two years, not a second of downtime with no intervention/admin required.
In my opinion, if you have a regular PC with i3 or i5 processor and a 128GB (or 256GB) SSD on it, you can as well run Roon Core on it. It is a valid alternative.
If you plan to put it in the attic, you will need Ethernet (or Ethernet-over-mains adapters) to connect it to the rest of your streaming device(s).
