Samsung s10 up sampling and it is not enabled…help
it keeps up sampling to 48 bit and I am not sure why. What should I do?
It’s an Android thing … everything is resampled to 48kHz by the OS, so Roon does it first as it does a better job. There’s nothing you can do.
The only solution is using an external dac and the USB Audio Player Pro app. I’m using the Ztella MQA enabled dac that is available for about 60 euro.
