Schiit Modi 3 problems
Hi
i have a problem with roon and my Schiit modi when it changes tracks or i skip i get a message of Audio device in use but its in exclusive mode and no other program is using it this is kind of anoying
if any one has a solution pleas help
Hey @Jose_Eduardo_Esparza,
Thanks for writing in and sharing your report!
Based on a recent diagnostic report from your Roon Server, we see a new device (NVIDIA High Definition Audio ) is detected right before the error which can cause Roon to lose access to the current device.
Is the device configured in WASAPI Shared mode?
See if you can:
  1. Disable unnecessary audio outputs in Windows : Go to Sound Settings > Playback Devices, and disable unused outputs like NVIDIA HDMI audio
  2. Restart Roon and try playback again after making the above changes.
If your issues still persist: Test playback with another DAC or endpoint to rule out issues specific to the Schiit Stack or its driver.
Can you share a screenshot of this?
Thank you! :raised_hands:
