I am having a very similar issue with scrolling the play history queue on a windows 11 laptop. I see the same but much worse jerky behaviour both scrolling arrow up and scrolling arrow down that results in a system crash.
Scrolling up and down with the track pad plus finger gestures seems to be more stable.
Hey @StefanK , I just wanted to let you know that our latest update, Build 918, has resolved this scrolling issue. Can you please install the latest version from the app store. Thanks!
Hi @jamie, I just retested with build 918 on iPhone 11 Pro, iPad Mini 6, iPad Pro 11 (2021). In all cases the issue is still present and not a bit better than before. Does not matter if in portrait or landscape mode.
Scrolling down works fine (as it was working also before).
Scrolling up is jerky on all the 3 devices.
Thank you for sharing what you’re seeing. We’ve received similar reports that the problem persists on tablets. We’re looking into it and hope to have more details to share soon!
@jamie , @support
Just tested on iPhone 11 Pro, iPad Mini 6, iPad Pro 11 (2021) the scrolling issue on compositions view and it is still there on the new build 923.
Don’t understand what kind of testing is done to check the issue is resolved as it was already two times reported as fixed in the two last builds.
To test the issue just search for example for “Piano sonata No. 14”.
I would suggest you open again a mew beta program, where the developers can get direct feedback from the community.
Scrolling issue is very simple to reproduce: scroll down and then start to scroll up. Scrolling up is very jerky
I installed Build 923 yesterday and am now having the same problems that others have reported.
My details…
Quiet PC Windows10 pro 64 bit, Intel I5 CPU, 16GB RAM
Main Library Storage area Samsung T5 1TB USB-C SSD
BT Smarthub 6 router, wifi via BT Whole home 6 mesh wifi & Trendnet Eco network switches. Core = ethernet to router.
Core connected, via USB, to Chord Mscaler/Dave
Additional endpoints Muso, MusoQB, iMac.
Controlled via iPad 12.9pro, iPhone 13. iMac 24”
Library Size
28K+ tracks
Prior to build 923 the scrolling issues described were barely noticeable, after installing 923 the issues are now very noticeable and a nuisance, scrolling up is very jerky/choppy…
My apologies for not jumping back in with an update sooner. There’s a new ticket in on this issue and work is underway. Thank you for letting us know that you were still seeing this behavior. We hope to have it remedied soon and appreciate your patience and courtesy during the wait.
