Mac Mini with directly connected USB hard drive. Roon 1.7 (511)
n/a
n/a
One folder of music on USB connected hard drive works fine. Pointing to another folder on the same drive gives message of “This directory appears to be empty” which of course it’s not and music in that folder (FLAC for example) will play just fine off the USB drive from VLC.
The drive is formatted NTFS so I had shut down roon and connect my PC to the USB drive to try your suggestion. However ultimately I couldn’t really check your suggestion as when I reconnect the drive and restarted roon, the other folder started importing!!! Very strange since essentially this same disconnect then restart procedure had been done before. Whatever the reason, my wife is now happy. Thanks for all the prompt responses. Happy holidays!
I’m glad that things are working for you now! Please feel free to reach out if you ever have any other questions or issues. Happy listening, and happy holidays
