I use a macbook pro and I connected a topping dx3 pro via usb. I ask you how I should perform the audio setting?
Can you elaborate on the specifics of how you’d like us to help? Are you having issues using this DAC? Are you seeing any errors? Is playback working okay?
It works well. however I can’t find a tread where the setting is indicated
it’s right?
Hello @giovanni_bertolotto, everything looks like it’s functioning as intended here. If you have further questions about your options with Roon or want to learn more, check out this article.
