How do I setup remote with iPad. I’m on a Mac
You install your Core somewhere (is it on your Mac?). Then run Remote on the same network. You can get Roon Remote from the App Store for your iPad. The Remote, on first start, should list the available Cores it finds on your network and you select the Core you want to control.
