I am a newbie to Roon and currently running the core on my MacBook Pro laptop.
I want to build a Roon core unit and went out and purchased an Intel NUC10i3FNH unit and the needed RAM and SSD and drive. I see that the NUC10i3FNH has a fan. Before I started putting things together I wanted to get some guidance on noise. Should I find a fanless NUC? I looked at the Roon help information on ROCK and all of the recommended units have fans. Is this something I should be concerned about? Thanks for any help offered. Anyone using the NUC10i3?
I’m also running ROCK on a NUC10i3FNH. The NUC sits just behind my listening chair and I’ve never heard the fan come on either. Not a concern as far as I’m concerned
FWIW, I set up a NUC8I3BEH yesterday to run ROCK and the fan can only be heard if I place my ear directly above it. Move away and it’s not noticeable at all.
That depends on the number of tracks in your library and the extent and type of DSP you might be planning on doing. For example, DSD conversions require more horsepower.
