Same problem here on Iphone 12 pro max here, can´t access “display” settings, if I try this, the app crashes…
Same here. On iPad and Android phone it’s fine. Only broken in Windows app.
Version 1.8 installed flawlessly on core, iPad Air 2 and Windows 7 (yes, I know).
But the iOS app crashes every time I tap:
- settings
- my tracks (both via a bookmark and the main menu traks button)
- manage profiles
Also on iOS, the top of the screen, with clock, battery load etc., is coloured grey in stead of black in dark mode.
iOS app crashes when choosing settings.
Crashes not only when selecting settings. But also when choosing history. Here it is even worse as you cannot restart the app but need to reinstall it. This on an iPad mini 5th Gen. Language German(Swiss) and Roon in English. Changing language to English in preferences of the IPad helps to fix it. Changing language in Roon does not help. Funnily, on my IPhone 12 Pro, same setting iOS in German, Roon in English works no problem, can access settings and also History. Hope this helps to debug.
+1 on iPad Pro 10.5
settings → crash
rotate to portrait → crash and doesn’t open anymore
deleting / reinstalling the app doesn’t help :-/
Mac App works though.
Let’s hope for a quick bugfix.
Seeing the same behaviour: settings on Windows is incomplete, settings on iOS leads to a crash.
Crashes at two different iPads by entering Settings , at iPhone it crashes on different sub Menus in Settings
Also crashes by entering Profile
Set IOS language and roon app language to English. That helps against crashings.
Many problems here
Ipad pro don’t have any settings, only shows ‘general’
The same on the Windows app.
Iphone 11 pro has settings but crashes on ‘display’ and ‘extensions’ tab
Extensions which don’t work at all.
Not a great job it seems it’s released to early
Reinstalled and switched from german to englisch - but still ist crashes
Malte, did you switch the system language or the language in Roon. Changing the sstem language to English solved the problem.
Okay - yes, with set iOS language also English it work , nice workaround
I can confirm that.
IPad language set to english makes roon work even with roon language internally set to german.
Strange bug.
Maybe more international beta testers next time?
@dylan can you confirm that, more specifically, you mean US English? I use U.K. English and have the issues.
I ask as I use my devices for business and I am loath to do this as it changes other system wide formats and defaults when you do this.
Not for me. I have Roon language=English, system language=German. And I get crashes as soon as I try to tab “Settings”
Hello, I have changed my system (Windows10 / 64bit) to English. Then back to German. Since then the problem with the settings has been fixed.
Greetings Arnold
A me sull’ IPAD non mi fa entrare in impostazioni, mi va in crash.
Provato con diversi linguaggi.
Also there are NO tags in album’s track list!!! It’s very BAD!!! Return them back as it was before !!!
Using ipad pro and rock on nuc8i7
Roon app crashes when going to setup screen
Is there any workaround - new installation of app did not solve the problem
