Shuffle/Repeat Highlight Issue in ARC on CarPlay [Ticket in]
· CarPlay / Android Auto issue
When playing music in ARC with Carplay. Iphone 15 pro in a subaru outback 2022 with the large screen the shuffle/repeat button does not highlight when selected
core hard wired on i5 13600 with 64gb ram on SSD drives. Windows
Hello @Francis_Vermette,
Could you kindly provide a screenshot of the issue, along with the device model and firmware version you are currently using? This information will help us investigate further.
I am using an IPhone 15 pro with latest iOS 18.5
I have had this issue for years through multiple updates of both Roon Arc and IOS.
Multiple reinstall of arc also. I have also done the updates to my Denso system in the car.
Here is a video of the issue
Thanks for sharing the video above @Francis_Vermette! We’ve shared your case with our Arc development team for further analysis.
Once they review your issue in more detail, we should have more information to share. Thank you for your patience in the meantime!
Hey @Francis_Vermette,
After you select one of the playback options, and check the queue screen, is the function applied even though the feature doesn’t remain selected/highlighted?
Or, are you seeing a complete failure of triggering across the board?
The function works as expected but the button is not highlighted when turned on. Same for repeat which works but will not show/highlight
This has never worked for me for at least a year.
All devices are always kept up to date.
Thank you for your update.
We have shared your feedback with our R&D team and will get back to you as soon as we receive new information.
