I just updated earlier this week with the new version.
I suddenly cannot sign in to Tidal via Roon on my iPad. It says there is an error in my user name or password. I can, however, sign on to Tidal’s website directly with no problem using the exact same password and username.
Last night, in Roon, I set up a new Qobuz account without any problem. However, Roon will not allow me so sing into Qobuz either, again giving me a username or password error. I can go to the Qobuz website and sign on without any problem, the same as I am experiencing in Roon.
Both Tidal and Qobuz are showing as unconfigured in Roon, and I urgently need to get this issue fixed. Thank you for any assistance.
Thank you for the suggestions to reboot the core device. The results are very strange though. I did reboot it, and now, I can again sign in to Tidal in Roon, however, it still says I have a bad user name or password for Qobuz while using the very ones I signed into this forum to get help with. Another reboot?
The Qobuz login credentials aren’t necessarily the same as the Roon login you’d use here. Are you able to sign in to the Qobuz app using those credentials?
Really not sure what to do here, and I’ve now lost two days of my free 30 day trial. I am looking at moving to Qobuz from Tidal based on a number of people I respect who say it simply has better sound quality. But if I can’t get it working, I have no idea!
This happened to me too. Actually twice.
I restarted server etc. The only thing that helped was edit the Qobus infos in settings, strangely my password was blank. Put it back in and it worked.
I did log in to the Qobuz webplayer you provided the link to with no issues. No luck when I just tried again in the Roon settings/services on my iPad Pro.
My apologies, I somehow missed this direct e-mail amidst all the other Roon
messages I had received. I have followed your instructions and changed the
password to [mod edit, password removed from post] ******** as you asked. Please let me know what you find. I’ve
already lost a week of my free monthly trial subscription to try Qobuz! Thanks for your help.
Hello Dylan. I sent you e-mails on both Jan 9, and 22nd, as I need some information from you and have not heard back. Please check either e-mail and reply with the info. Thanks.
