It is a while now I wanted to ask if this is all right but basically, when I click on the “light” showing the signal path and sound quality, it shows me a whole bunch of stuff (see attached image).
The conversions happening before the signal is passed on to your endpoint are done in Roon and because you have applied volume leveling (in Roon). If you click on the purple text, it will explain why. Perfectly normal behaviour.
The last conversion is done by your endpoint (the Cambridge) and it appears you are upsampling.
As a fellow CXN V2 user I would recommend set the “Max bits per sample (PCM)” in the device setup fo the CNX V2 to 24bits. I know this shouldn’t make a difference but for me it does. The CXN V2 is 24/192 even though Roon sets it to 32bit per default.
As @RBO says, this is done because you have enabled volume levelling. Performing bit depth conversion ensures accuracy in the signal processing (note that these steps do not affect signal quality.) The CXN performs the final sample rate conversion.
As @TheHammer said the CXN V2 when used as a network streamer does upsampling to 384kHz using their ATF2 technology… You can’t disable that feature. When you use the CXN V2 as a dac via usb it doesn’t. The dac part is 24/192kHz dual wolfson WM8740. By using it as a dac you are bypassing the upsampling stage.
While some may claim it is “unusual” or “strange” for the CXN v2 to upsample to 384, the procedure is well documented in the marketing material for the unit. Most reviewers seem to like it. I have no complaints.
To clarify, what I mean is not that it is strange for the CXN to upsample but for it to upsample without giving the user ANY choice in the matter or options.
That to my mind is an unusual way to implement it.
The upsampling does not occur if using the CXN to pass the digital stream on to another DAC, it is only done when it is being used as the DAC and doing the conversion to analog.
From their website:
Upsampling only occurs when using analogue outputs as the process is implemented within the digital to analogue conversion process.
However, the CXN seems always report this upsampling to Roon whether it is doing so or not.
