Apple TV AirPlay Streaming
Red Dragonfly DAC
I recently added a Red Dragonfly DAC and signed up for Qobuz.
When I check Signal Path, this is the thread:
Source Qobuz FLAC > Bit Depth Conversion 16bit to 64 bit Float > Volume Leveling +0.1 db > Bit Depth Coversion 64bit Float to 16bit > Apple TV AirPlay Streaming.
Not sure I’m getting best quality. Source signal is purple but at the end of the thread, it’s green. Should it be purple all the way to output?
Ok, so ditch Apple TV and get a network player? Speakers are powered by Integra A.V. receiver. Does it even hook up to the receiver?
I’m really enjoying the streaming experience but know I’m not taking full advantage. I’ve been napping since CDs were it.
Thanks for the answer. That’s what I thought but I wasn’t sure.
If your AV receiver has a spare HDMI input pick up a Google Chromecast and use that as a Roon endpoint. While Chromecast is not a full RAAT device, it is still a big step up from Apple TV.
Well then pick up a Pro-Ject Stream Box S2 Ultra, a nice little Roon Ready, full RAAT endpoint with several digital outputs and under a grand: Stream Box
“Little” is the word. I was walking down the street on one of my work trips to Zürich last week and saw it in an audio store’s window, it’s teeny. For less $$$: https://allo.com/sparky/usbridge-signature-player.html. Needs a wifi add-on if you can’t go wired, though.
There are plenty of less expensive Roon endpoints, some Roon Ready and some not (Chromecast, SqueezeBox devices) but the Pro-ject Stream Box S2 Ultra is easy to set up and works great. And it’s less than $1000.
The Bluesound Node 2i delivers a lot of value for about $550 (for a Roon-ready endpoint/streamer with built-in DAC). Some nice NAD or Cambridge Audio products go for 2x to 3x that amount, or so. The Sonore ultraRendu plus a power supply should go for under $1500.
