Thanks for the details. We checked the logs from your Roon Server. The Roon Server side looks fine, and the problem is on the Silent Angel M1T.
Several times a day, the M1T stops responding to Roon. For example, it dropped off at 7:57 AM today and came back at 8:13 AM, and again at 12:40 PM (back at 12:48 PM). During those gaps the M1T refuses the connection from Roon Server, which is why it sometimes does not show up as an endpoint. We also see 111 cases over the last few weeks where Roon asks the M1T to play and the M1T reports that it cannot open its audio device. That matches the “can’t connect to device” message.
Please tell us:
Which firmware version is the M1T running, and is it on the latest one from Silent Angel?
Is the M1T connected by Ethernet or Wi-Fi?
Which DAC is connected to the M1T, and how (USB, coax, or another input)?
Because the M1T is made by Silent Angel, we also recommend contacting them with this information. The restarts and the audio device errors are happening inside the device, so they will be able to look at it directly.
Thanks for the update and for forwarding the details to Silent Angel. Please keep us posted on what they reply, and if they replace the unit, let us know how the new one behaves with Roon.
We’re happy to help. Should this thread autoclose before you have a follow-up to share from Silent Angel, please note that you can always reopen your case via the initial intake form:
Thanks for letting us know the issue is still there, and we’re sorry the M1T is still giving you trouble.
When we went through your Roon Server logs earlier in this thread, everything on the Roon Server side looked healthy. The problems were coming from the M1T itself: it dropped off the network several times a day and turned down connections from Roon Server, and it repeatedly reported that it couldn’t open its audio device. Those faults happen inside the M1T’s own software and hardware, so Silent Angel is the right team to fix them. From our side we can’t see into the device or change how it behaves.
Our recommendation is to keep the case open with Silent Angel. A few things that would help them:
Tell them the problem continued after your first contact, and if they already replaced the unit, say whether this is the original M1T or the replacement.
Mention that it happens over both USB and S/PDIF into the Audiolab D9, which points to the M1T rather than the DAC or the cable.
Forward the details from our earlier post (the dropout times and the “cannot open audio device” errors) again if you need to.
If you’d like to confirm that the rest of your setup is fine while you wait, you can temporarily connect the D9 by USB to your Roon Server machine, or to another computer running Roon Bridge, and play to it from there. If that works reliably, it’s one more piece of evidence for Silent Angel.
Once Silent Angel replies, or if a replacement unit shows the same behavior, please post back here and we’ll be glad to take another look at fresh logs.
We’ve gone through your Roon Server logs for the past week. The pattern is the same as in October: the M1T dropped off the network and reported that it could not open its audio device. Roon Server itself ran without errors over the same period.
That keeps this with Silent Angel. Has their support replied yet, and is this still the original unit?
A note on the test we suggested: it did not involve moving the Mac mini. The idea was to connect the Audiolab D9 by USB to a computer running Roon for a short while, to show the DAC plays reliably without the M1T in the chain. It is optional, so skip it if it isn’t practical.
