Thanks! I mis-understood the test you ran there. I will be sure to add this information to the ticket so we can get to the bottom of this. Thank you for your patience!
I discussed this issue with the tech team today, they would like for you to run this test to further reduce to scope of where this issue could be stemming from
Rename your “RoonServer” folder to “RoonServer_old”
Re-download the RoonServer installer from our website, and reinstall Roon Server without any elevated privileges such as Admin
Do not do a restore of your old database, do a full fresh startup. Note that it is not necessary to add music files for this test
When you have reached the Roon home page, go into Audio settings and see if the device picker is available.
I discussed your situation with the development team, they believe that there is something on your computer that is preventing either the download or the unzipping of our Roon device identification bundle to complete successfully. Do you have any anti-virus software installed on your PC? Do you use any VPN software?
No Anti Virus (except the built in windows antivirus) and no vpn. And I also would not know about anything else that might block it. It is running on a no-BS vanilla win10 NUC where the only additional software installed is Kodi, chrome, and Roon.
The issue does not occur if I just run Roon Core. It only happens with roonserver
