What app are you having the slowness issue with?
· Roon
What kind of performance/speed issue are you experiencing?
· Tracks take a long time to play
Please try to reboot your Roon Server
· No, the issue is still the same even immediately after a reboot
Please try to reboot your networking gear (Router/Switches/etc.)
· No, the issue is still the same even after a reboot
Is there any change in behavior if you try to navigate to Roon Settings -> Library and set both Background and On-Demand Audio Analysis to Throttled or Off?
Does the issue happen on multiple Roon Remotes (controllers) or just one?
· Issue happens on multiple remotes
Router Domain Name System (DNS) change
· I was able to change my router's DNS servers but it did not help
· MacOS
Timestamp of issue occurrences
· 18/03/2026 at 18:20
I am seeing a reproducible problem with Roon when using TIDAL.
My setup is: Roon Server on Mac mini, Holo Audio DAC connected by USB to the same Mac mini.
The issue is that when I start an evening listening session, the first track of the first album often takes about one minute to start. After that, changing albums or tracks is usually much faster. Native streaming performance is much better, so this appears to be a Roon–streaming integration issue, not a DAC or general internet-speed issue.
Given the cost of a Roon subscription, this is a serious problem because streaming-service integration is one of its core functions.
ISP is Telekom.hu
