Very recent Roon user and probably my questions don’t make much sense…
I have a very small library for now, and I have a 256GB UBS3.2 stick that can easily fit all my albums. Would it make sense to use the USB stick as a Roon library or better to use the SSD drive, which is the same where I have Roon installed?
I’m using an old DELL i5 8th gen with 8GB RAM, running Roon on Linux.
As stated above ,as far as I know there is no requirement NOT to use the SSD containing Roon, that’s a limitation applied by ROCK not Roon running on a normal Windows PC
Thank you all
I will move the files to the SSD. My concern is if that would impact roon performance since I have Roon server installed in this same SSD.
By the way, I’m not using ROCK, I installed roon on a PC running UBUNTU (Linux).
