NUC8i7BEH running latest Roon Rock. 27" iMac as Roon remote, sometimes my iPad as well. All are updated with latest Roon software
Everything is hardwired ethernet to unmanaged switch except my iPad which is Wifi
Lumin U1Mini connected over ethernet
I am using Roon Radio and have it set to only use tracks from my library. Sometimes when a new song comes on it does not play. It pauses for a couple of seconds and then switches to another track that usually plays fine. If I got back to the song that would not play, it then plays perfectly. Is there a setting I should try or something?
I use volume leveling and headroom adjustment. I sometimes use the Audeze settings as well.
All my music files are ALAC and mostly come from qobuz or HDtracks. So there is no pattern as far as I can tell. It happens at least a couple times a day.
I have not noticed it happening when playing song I manually pick, or if I add an album to the queue. This doesn’t mean it’s doesn’t happen I just have not noticed. I’ll try to pay more attention if there is a pattern
