Dear Roon,
If possible, I’d like to re-open the following topic:
I figured out what the parameters are for a song to fail playing: It’s when the file sample rate and/or bitrate change from song to song. that’s when the song wouldn’t play. But if you then try to play a song in that sample rate again (meaning: the second try), then the song always plays fine.
The same happens when using any kind of DSP in conjunction with HQPlayer.
Also, I figured out that turning the DSP on while playing a song always results in successful playtime.
Can we still say this is a performance issue? Or should we look further into this?
Hope we can work this out. Thanks again for the great support.
Kind regards,
Arash
