MY optical rendu is no longer showing up in my audio section of my Roon application; My system Is the SonicTransporter I5, with the HQplayer software, Mac air M2
Hey @Jeffrey_Sykes1,
We’d love to help offer some support and troubleshooting steps, but without including any details or additional information around your system setup, it’s difficult to do so.
How are your machines connected to your router? Set up a direct ethernet connection with your optical rendu as well as the ST and see if you still have issues.
I’d also suggest rebooting your router. After that, I’d also stop Roon Server from running, and safely power down and reboot your ST as well.
Are you able to see the rendu outside of Roon completely?
I’d lastly double-check your router settings and ensure all devices are on the same local subnet.
Hope this helps!
