Sonos speakers not showing as audio options on Roon Rock (ref#Q5SC0R)
Roon Rock is no longer showing Sonos speakers on my Sonos network as audio options. All of them have just gone!
It is showing them as Airplay options but even when these are enabled, they don’t play music and the track time indicator on the song stubbornly stays at 0.00. However that little indicator ( like a mini graphic equaliser) next to the speaker logo does move up and down to indicate it’s playing.
Music selection on Roon using Qobuz and my library is fully functioning as is its Ethernet feed to my DAC and WiFi link to play through my phone.
Sonos network working fine on its own,
BT fibre into BT Homehub 6 with direct feed to English Electric switch. Ethernet cable feed from switch straight to Roon Rock. No extenders in the home.
My Sonos speakers show but they don’t play. I get a couple of them with Apple TV and those work fine. Back in Sept our cable modem hardware was updated and since then I have double NATs. They want extra $$$ for a single IP address.
Hi @Dennis_Laslo1
Your post indicates you might require assistance from Roon technical support.
Respond to the prompts there to ensure that you’ve performed basic troubleshooting and to ensure Technical Support has the full details necessary to expedite Technical Support’s investigation into the case.
Your responses will auto-generate a Community thread in the appropriate section.
Because this Community thread will be in a public forum, please do not include any personal information, such as your email address, postal address or telephone number in your submission. Thank you.
If Sonos devices aren’t being discovered, check whether the UPnP option has been disabled. Roon requires UPnP support.
Hello @Carlton_Andrews !
What @Giles_W says is actually right thing to check.
after you complete the check list please power cycle your nodes (router + Roon Server machine + Sonos speakers) and check again.
let us know please if it works.
Have a nice day!
Regards.
Thank you Alex and Giles! I’ve followed his advice, restarted my Roon and the speakers are visible again!
