QNAP TS-251A
Celeron CPU N3060 @1.60GHz
8GB RAM
Firmware 4.3.6.0979 Build 20190620
Roon Version: 1.6 (build 416)
QPKG : 2019-06-09
Roonserver is running on SanDisk SDCZ880-128G-G46 Extreme PRO 128GB USB 3.1
Netgear 16-Port Gigabit Ethernet Unmanaged Switch, GS316
Netgear Orbi RBK50 Router
Netgear Orbi RBS50 Satellites (Qty 2)
QNAP and all Orbis hardwired to switch
Apple Airport Express A1392 - Connected via wifi - Firmware 7.8 (78999.12)
I’m two days away from my subscription starting, so I’d love to find solutions for these issues because when Roon is running, I see the potential.
I have two issues, not sure if that requires two threads.
First is the sound drops out completely. Tracks appear to continue to play and will come back 30-45 seconds later. Other times, the track will stop and I’ll have to press play again.
I have very good wifi coverage with the 3 Orbis and have no streaming issues if I use Airplay for other software.
The second issue is that my remote (iPhone X) loses connection to the core. Other remote devices appear to have the same issue once connection is lost. The only resolution I’ve found it to restart my NAS.
Should I post the log file?
Thanks,
C
