Youâd think that if sound quality had âdegraded significantlyâ significantly since the 806 release in July, some others might have mentioned it?
Folks here will want to see a screenshot of your signal path to start with.
The best way to avoid these sort of problems (for the future) is to maintain a full system backup of the core so you roll back in case of an issue (whether itâs related to an update or not).
Canât say for others, but two friends of mine that I trust their opinion, agreed with me. They heard degradation on their, different, setups as well. Probably, not every setup can reveal these differences and not everyone who hear will write about it here.
In general, the sound lacks stage (width and depth), transparency and detalization. Iâd guess that this is due to somewhat trimmed frequency edges (low & high).
you have a nice system but there are plenty of people here with equal or better (more expensive) systems and there are plenty of posts from people in that past who have complained about sound degradation in the past. Donât fall into the trap of thinking you are specialâŚ
Is this perceived reduction in sound quality just with Tidal or do you have local content as well? [edit: ok you mentioned flac content also so not just Tidal I presume].
Does the Tidal app sound better when playing Tidal content?
Both of whom also donât take backups of their system either I presume!
Do you not have the .exe that you used to install Roon core in the first place? If so, uninstall Roon core and reinstall from the original (older) .exe
Basically unless a bunch of people come out of hiding to agree with you, this thread will go nowhere, especially as you are playing MQA content for which many people have âdivided opinionsâ.
Build 806 seems like a long time ago (months?). There are a lot of possible explanations. Applying Occamâs razor, changes to Core seems pretty far down on the list.
âExpensiveâ doesnât necessarily mean better sounding system. My point was that one, to hear the difference, probably, needs system that is capable of proper handling of <50Hz/>12kHz and having neutral tonal balance .
Tidalâs app never sounded better than Tidalâs content through Roon. PS Audio MConnect app always sounded different, so, comparing it to Roon will not be apples to apples comparison.
Performing system backup when updating the core?! Come on, we are in 21th century! Even MSFT doesnât ask for it when new Win10 versions comes out.
It doesnât matter whether it is MQA or FLAC - the sonic change between the builds is there.
Not sure Iâm following⌠Same setup for years. Nothing changed except Roonâs build.
I heard the difference immediately after upgrading from 806. 831 introduced improvement over 816, but stillâŚ
and my point is that you are implying that other people havenât reported this degradation in sound because their systems arenât as âresolvingâ as yours and Iâm saying that is not the case. there are plenty of people here with systems that match or exceed your systems resolving abilities and none of them are complaining about the sound.
There is nothing in the 814 update that is even related to the signal path
# Improvements and Bug Fixes for Build 814:
** Resolved issues automatically updating Roon Bridge*
** Updated presentation of bit depth/sample rate information for consistency*
** Resolved a bug causing unstable generation of Daily Mixes and other recommendations*
how does the signal get to your DAC. It is via USB from the Dell PC?
Roon have said (use search if you must) there were no changes made to any âaudioâ code, just database stuff. Psychoacoustics can be a powerful drug. Light some candles, pour a double, and enjoy your favourite track!
I have Roon in two homes (different countries) with three different DAC/amp setups in each (different rooms). Iâm almost exclusively a headphone listener. I havenât heard one bit of difference in sound quality with any recent Roon update, anywhere in my six setups.
