Popping sounds in songs when playing from the Bluesound Node USB output.
Two questions:
Has anyone else experience a sound quality degradation when using Spdif/coax output from the Bluesound Node to their DAC to get around the USB output popping problem?
What other Roon Endpoints with a USB output produce sound quality equivalent or a little better than the Bluesound Node, without the popping, at comparable or better price (yes, I’m thinking of replacing the Node in my system)?
Yes, I do have the Spdif option. However, the sound quality on my system is lower when using Spdif, more specifically, I loose detail and clarity, which I spent a lot of money to achieve.
What we don’t know is if they will solve the problem, and if they do solve the problem, when…
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
4
And that pretty much sums it up ATM.
However I would likely opt for a bit lower detail quality than any pops or cracks.
