Beware the power of the volume control ![]()
You do not have to wait for anything. roon offers their own built-in DSP/MUSE which even supports “room correcting” FIR filters. With this you can adjust the sound to your individual preference. Just try it. It’s extremely effective.
In case you need to know more about the very different natures of analog and digital audio signals and their processing, teach yourself. It’s very interesting and may open your eyes and ears.
But as a matter of fact, there’s nothing more roon could to regarding listeners’ preferences. It’s not about SQ.
I attended a presentation at my local HiFi dealer a few years ago where some very expensive and well known cables were being shown by the company’s representative.
He did a back to back comparison of two USB cables, playing a track with first their least expensive cable, followed by the same track using one that cost considerably more.
With the second play of the track, I listened intently, but with an open mind to see if I heard any difference from the less expensive cable. Sure enough I heard clear and beautiful guitar notes that seemed to stand out with a wonderful sound that I didn’t seem to remember with the previous playing.
But almost immediately I thought “wait a minute, play the track with the first cable again.”
I am convinced that by concentrating on listening to hear any difference, of course that’s what I heard. The company rep notably didn’t play the track again with the affordable cable. (I assume there was no manipulation of the volume, or any funny business)
Delusion is a function of our brains, built-in from the very first day ![]()
Actually, it does. Not in the sense that the sound is “perfectly good” (a 1935 mono Furtwängler recording is not going to improve in sound because it’s delivered in bit-perfect 24bit/192kHz), but in the sense that the sound is the same, no matter how that perfect bit stream arrives.
And bit streams are usually “perfect”, unless there is a heavy disturbance of the force… I mean disturbance in your listening chain.
Which is why it’s highly unspecific to encourage Roon to pursue better sound quality… how? What is Roon supposed to do exactly?
There are two options:
The settings of your playback are so that the original source PCM goes into your DAC unchanged, in which case it is literally impossible for Roon to sound any different from any other app that delivers the same PCM.
Or, you use DSP, or use different DACs/inputs into your amplifier, or have otherwise differences in your setup… In which case it’s not Roon, but dependent on these settings and/or set-up.
That’s just fact.
Like the original post , I also have done the “Roon” test with frankly an enormous amount of equipment over the years. I’ll spare all the detail for brevity sake but please know I have been fortunate enough to have and have had a fair share of TOTL equipment so much so I barely escaped the “almost got divorced” audiophile club. I will emphatically say (note this is IMHO) I have and do hear a difference with Roon. I also currently have innuos gear as well. Roon is so far and away the best audio software in the world IMO again that I keep trying to love it, set it and forget it ( that thing that says its “in the mind” has a lot merit to a point. In my case I keep trying to prove Roon does not provide inferior SQ) even though I do hear differences so don’t currently use it daily. Now before this draws the regular backlash allow me to continue. After all if you spend thousands and in some cases tens of thousands of $$ for the best possible SQ performance available its not totally unreasonable to be fixated on this issue. My current innuos stream1 with sense like Audrivana, MiminServer feeding Mosaic, JPlay, MConnect etc and others control apps have and can sound more open and dynamic during playback. Roon to my ears seems at times to be more “Vailed” in its presentation. Now that said (wait for it) I have concluded from my back and forth testing that quite possibly it is not Roon at all that’s at the bottom of all this, but rather its the Music “CHAIN” for a limitless number of reasons ( I don’t know why) Roon can perform noticeably different depending on your CHAIN. Example, Roon over a network? Roon using USB, Roon as an endpoint , Roon core on a roon appliance vs a NAS/Computer, vs a server like sonic transporter etc etc etc. The very first time I got hit with the Roon can sound “Different” bug was the I traded my nucleus one for a sonic transporter. It opened my eyes and ears immediately. Then there were other examples like that which did lift the Vail? So my bottom line is both camps can have a real point in the discussion. Roon is send the same signal as all the others period. That’s just a Fact.That said How that signal path is constructed is what I found to be the difference. Again by example . I ran my test tracks (sick in that many of us have test tracks just for this purpose) Setting up roon with the innuos as a endpoint, the Innuos as the roon core, the innuos and roon connected via USB the innuos and roon over my network input. Surprise they all sounded a bit different. now you can get crazy here with tons of examples but my point is this…its less about Roon itself and how you set up your chain… I found I enjoy(notice I said enjoy not Better/Worse, Innuos and roon when roon core is on the innuos and my Aperio input is set to network compared to roon on innuos as an endpoint and the aperio input selected via USB. Hence again with many configurations and components I’ve tried over several years, the road the chain creates to roon is where all these discussions come from. I have found that a clean noise free connection properly isolated with proper power etc etc etc make more difference than any software. Hell maybe roon sounding different in many of these cases actually supports the depth of the software as it is so adaptable . So I respectfully wish the conversation could focus less on the software control app and more on the actual make up and set up of the chain that you will run your control app on. One last example, I ran Audrivana on my MacMini with my music files configured so audrivana was pointed to my files on a Nas. I then bought a sonictransporter when I learned It could run the audrivana core on it and pointed it to the internal files on the transporter. That made Roon sound less “Vailed” to my ears. Do I know why, not really but consider maybe less noise, my ethernet connection, a more stripped down server purpose built to support Roon than my Mac all make sense is probably more of what contributed to whatever sound difference I preferred?. So bottom line for me is Roon, Sense, Audrivana, Jplay etc etc. Its the components, and how they are connected and the chain the music stream/local file runs over I believe to be a better focus of our efforts and conversations. Again for me with all the noise around Roon. Roon remains too good to ignore so although I am currently using sense I continue to explore the best way I can find that complements roon to provide that preferred experience which I call less “Vailed” I wish it was not the case and I could put this to bed but I do hear differences. I believe Roon has no peer overall in comparison to other music software control apps out there today! So today right now I am going back and forth between sense and roon in various configurations with Roon set up via usb then roon via network on an innuos server stream1 , I go back and forth testing tracks searching for the best combination to break the fever once and for all…I apologize im a bit rushed for time or I think I may have been able toexplain myself a bit more clearly. I remain hopeful this can be some food for thought for some…BTW this is not unlike the endless IOS vs Android never ending conversations…In the end its all about the Music and your preference in enjoying it. I want Roon to win this race because its a pleasure to use.I continue my explorations…
1 cow
1 beef burger factory
2 beef burger patties from the same cow
2 vendors (Burger King & McDonalds)
2 burgers
2 different tastes
Just saying
Must be the secret sauce…
I hear you…
You asked “What is Roon to do,” and my answer is “Benchmark!” Leverage multi-purpose platforms like Innuos or PCs, while holding the network constant, to compare Roon with its competitors. That’s how you hone your SQ. EQ is irrelevant, if the SQ of the native app is not competitive, more processing won’t help.
Benchmark what? You seem to assume that apps can have different sound quality even when delivering identical PCM to the identical DAC, which is verifiably false.
One subtle point from my post is the network didn’t change during my comparison. I’ve put a lot of work into network hygiene, but it’s been a rising tide that has lifted all boats. My point was that, given identical hardware and networking, Innuos Sense was clearly better for SQ. Roon obviously wins for UX and I’ll continue to use it most of the time. But for critical listening, I’ll switch over to Sense.
Roon needs more than purely subjective personal experiences before going on a wild goose chase to improve “sound stage” and “vocal images”. It has to be measurable, otherwise the result might depend on what the “SQ tuners” had for dinner the night before.
And it’s still dragging the same old story through the village ![]()
Again, the whole story does not end with delivering bit identical audio data via two different apps/systems or audio protocols.
A rendering endpoint could easily separate further digital processing depending on different protocols used like e.g. roon via RAAT, app x via USB, app x via UPnP/DLNA, etc.
Active speakers for example are known for heavily relying on internal DSP.
The whole chain does not end with sending identical audio data.
From receiving this data up to pushing it into a DAC (chip) many things can and do happen without letting you know.
So don’t always blame app x or y for delivering bad or magical SQ. That’s totally oversimplified.
And again, technical sound quality is not the same as your preference. They are totally different things.
Unless this fundamental knowledge is not understood or is just ignored the whole blaming is pointless, naive and senseless.
A measured digital signal (just before a DAC chip) or an analogue output would reveal facts. But this will very likely not happen in a professional manner.
IMHO ![]()
Ah, the “measurements” defense. You may recall that the high-end audio industry was launched because measurably perfect components didn’t sound realistic. The same paradox holds for digital, as witnessed by the plethora of five and six figure digital components. It may be instructive to repost your assertion the What’s Best Forum and gauge the consensus.
How is this defined?
If something sounds like something or doesn’t there’s obviously a listener in place who judges the sound regarding… what…? A subjective preference in a given room.
And that’s totally fine, but don’t call it technical sound quality. It’s tweaking the technical sound to a wanted sound signature which most manufactures have, for their own aimed customer group. It’s by far not necessarily about making the sound more accurate. They don’t know each and every listening room, anyway.
But finally saying a preferred sound signature would by nature show a better/more accurate technical sound quality is simply false.
And a sound can never be perceived and judged without a room. So guess what, many manufacturers tweak their speakers to an assumed average listening room the targeted customer would use them in. Also bypassing the idea of a perceived linear frequency response. Even if a DAC would output an almost perfect linear response.
It’s all about preference and esp. targeted preference. In the end companies have to sell their products.
If you prefer a certain sound signature over another one, then this is totally normal and fine. We are humans with all their different preferences. But preferences are something different than measurable technical qualities.
We are not identical machines. We perceive and judge sound very individually. That’s part of our nature. You should never ever forget about the brain in the end. And this is by far everything but a neutral, reliable and unbiased sound measurement tool ![]()
Coming back to 1:1 unaltered audio signal. It is not to convince you to actually listen to this unaltered signal/sound which anyway passes some analog speaker mechanism and gets reflected in your room almost endlessly.
You don’t have the slightest chance of experiencing a real 1:1 digital signal as a nearly 100% matching analog sound wave reaching your ears. The speakers and the room make this impossible.
So, what reaches your ear isn’t the original signal, anyway. Physics.
What now…? You either prefer the sound of a particular track going through a particular gear combination, in a particular room… or not.
Is this a problem of an app actually delivering an unaltered digital audio signal to some gear from where the sound goes through a far more complex physical process reaching your ears…?
Nope.
But some of such apps like roon offer you a fantastic tool which helps you tweaking the sound more to your liking and room, without applying unknown changes . It’s called DSP, or MUSE in roon.
An unaltered digital signal is the base for further tweaking the sound to your liking and room, in case you feel this would improve your very personal perception in your very individual listening situation.
You can define high-end in different ways:
- Measurably perfect in terms of audibility.
- Made with precious metals and/or gems.
- Whatever audiophile reviews call as such.
I go by #1. What I recall is that, when audiophiles didn’t know what the price of the equipment they listened to was, they either randomly guessed or picked the good measuring one.
The only thing witnessed there is snake oil proliferation fueled by ignorance and FOMO. It’s a circular logic anyway: it’s real because the components exist, and components exist because people think it’s real. Measurements are not a defense, they are a reality check.
Yes, totally different things. Preference is individual, there is no “right” or “wrong” preference.
Now my basic claim stands:
If the PCM entering the DAC is identical, then sound quality must be identical. It’s predictable output.
However, when you say that a rendering endpoint could easily separate further digital processing depending on different protocols used, that’s of course true. But then we’re not at “Roon sounds better or worse than app xyz”. Because then it is device dependent.
Because while a protocol does not change the PCM, a device can change the DSP depending on protocol. But again: then it’s device (or “chain”) dependent, and it’s not a question of Roon vs. XYZ, it’s a question of the DSP of the device.
It seems to me that there is an ever increasing number of posters who find roon’s sound inferior. That alone should cause a stir around the roon developer’s water cooler.
