I recently found myself with a spare Cobalt after i got a Hugo. Using my laptop as a Roon endpoint and with the Cobalt connected, i can connect it to the Cinema amp via a headphone to RCA, this works well.
My question is, what can i use to replace my laptop, i’m looking for something that can remain in situ and on 24/7?
Cheers.
Bill_Janssen
(now wearing snowshoes on my asymmetrical isolation feet)
#3
A Raspberry Pi running RoPieee is the default cheap solution here. Buy the Cana kit on Amazon.
Consider using DSP volume control with the Dragonfly Cobalt instead of Device Volume. I’ve had it jump to max volume at random but rare occasions when set to Device Volume in Roon. That doesn’t happen with volume control set to DSP.
Of course you could always get a DAC HAT for the RPI. Freeing up the Cobalt to be used for something else.
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
#11
Interesting.
I just found an older Dragonfly Black in a desk drawer and plugged it into my PC with a pair of B&W cans connected to it.
Set to device volume in settings.
Yup!
Three times today it shot to max volume for no good reason I could see.
Not sure if it’s a, “known”, bug but definitely a bug. I’ve used device volume with no problems on a couple of devices from other manufacturers. I suspect it’s something to do with the Dragonfly products. I only use them in software volume mode with Roon. Doesn’t the Dragonfly Black have its own volume control?
