I have seen that search is slow, about 5 seconds before anything shows up, even the artist name (artists I have in the library). I just testedright now, with Miles Davis, and it took 15 seconds 7til anything showed up.
But I found another strange effect. I selected an album, by just clicking in the album browser (Blue Maqams by Anouar Brahem). I have one version, a 96k FLAC. But in addition, Tidal has a 16/44 and an MQA, and Qobuz has a 16/44 and a 24/96, neither of which is in my library. When I opened the album, it appeared immediately, but there was a spinner on the Versions tab. I hit Play. Nothing happened, for about five seconds, until the spinner finished, then it started playing.
Happened with other albums, some local, some streamed.
In that case, I had nothing playing.
When I already had something, the precise sequence was,
Display shows the new album
Versions spinner is go8ng, no versions shown
The music keeps playing
After about 1 second, the icon in the Now Playing bar changes to the new album, no ther change
3 seconds more, the Versions spinner stops and versions appear
1-2 seconds more, music starts and the progress bar moves
Configuration: Nucleus, internal SSD, gigabit WiFi and gigabit Ethernet (tests show speeds around 750), playing to Meridian 818/8000, DSP convolution,
The final play delay is pretty normal, probably the 131k convolution. But the wait for the Versions spinner is new. I assume this is checking up with Tidal and Qobuz. There is caching, going back to Blue Maqams eliminated the spinner delay.
Tested with another zone, the final play startup is quicker, could be a Meridian thing, or no convolution. But the spinner delay is still there.
Everything is slightly faster now, both the spinner and search, finding Dave Holland took 5 seconds.
But overall it’s not a happy situation.
