Intel NUC i5 with Rock Version 1.0 (build 227) stable
Network Details
WRITE HERE
Audio Devices
WRITE HERE
I saw a post about how to get a bit-perfect endpoint on an Android Device, making it a Squeezebox server. I downloaded the app (Squeeze player) but I have no idea, neither is clear on the post for a newbie, on how to configure it (what ip address? The Roon Server one’s?).
Roon does not officially support the use of Squeezelite players. That falls under Tinkering and you might post your query there.
If you looked at bottom of the link Blackjack posted, it says this:
Squeezelite/Software endpoints: Roon does not support software implementations of squeezebox endpoints, and we do not test with them as part of our QA process. If you attempt to do this, you are on your own.
Only problem with sapling rate at 192khz is that songs stutter for the first few seconds, despite me having a pretty good connection at wifi. 96kHz will do anyway
Yeah I noticed that to on my R5 if the player is left to upsample as they really don’t have the grunt. Set it to 96/24 and it’s fine. But I don’t find using this method to be any better sq than using the Roon app asmost of my content it’s left untouched as it’s 44.1/16 or 24 which does not get touched on my Hiby R5.
