wired ethernet
IFI PRO IDSD
I wanted to connect IFI PRO IDSD to Roon. I have created Squeezebox for that. Butby mistake , I have created 2 squeezebox devices and they share same ip address. How can I remove one of them?
I take it your using the ifi Bridge software which makes the Ifi available as Squeezebox in Roon using Squeezelite. Its not a supported device so really this is up to you to work it out.
Just go into Settings/Audio and disable it. The bridge finds all UPnP devices on your network and will add them using the same ip as the computer the bridge is running on. Just disable one at a time to work out which is which. You cant stop them showing up in Roon you have to edit the Bridges config.xml to disable them.
