Mac Mini: Mojave
Roon: 1.6 (build 401)
Wired Connection
Router: Linksys WRT1900AC
Audio Devices (Specify what device you’re using and its connection type - USB/HDMI/ect.)
PS Audio Directstream DAC: Bridge II
Loud static sound when playing of 192/24 files end.
If i select and play a 192/24 album it will play through fine until the end of the last song. Roon will show Nothing Playing and a second or so later a loud static sound is heard.
If I select a single 192/24 song to play at the end the same static behavior as above.
If I cue up multiple 192/24 files from different albums they will all play flawlessly until the last song ends. Then the same static behavior as above.
If I cue up a 192/24 track followed by any other bit rate/DSD file there will be a static burst in-between the 192/24 track and the next. this happens with Roon radio as well.
This also doesn’t matter what the file format is. The same thing happens with FLAC, ALAC, AIFF…
I’ve done numerous testings and no other sample rates are having any issues…only 192/24 files.
Also, this behavior is only happening with Roon. The static does not occur when streaming these files with other applications.
